I’ve just Replaced my PI2 in my bedroom with a Vero4k but im getting buffering on my HD films
So I thought I would check the transfer speeds with iperf
Both iperf tests are connecting to the PI3 downstairs that is wired to my router
This is from the Vero4k over WIFI
Client connecting to 192.168.0.2, TCP port 5001
TCP window size: 85.0 KByte (default)
[ 3] local 192.168.0.3 port 46325 connected with 192.168.0.2 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0- 1.0 sec 2.38 MBytes 19.9 Mbits/sec
[ 3] 1.0- 2.0 sec 2.75 MBytes 23.1 Mbits/sec
[ 3] 2.0- 3.0 sec 3.38 MBytes 28.3 Mbits/sec
[ 3] 3.0- 4.0 sec 3.00 MBytes 25.2 Mbits/sec
[ 3] 4.0- 5.0 sec 3.62 MBytes 30.4 Mbits/sec
[ 3] 5.0- 6.0 sec 1.39 MBytes 11.6 Mbits/sec
[ 3] 6.0- 7.0 sec 855 KBytes 7.00 Mbits/sec
[ 3] 7.0- 8.0 sec 856 KBytes 7.01 Mbits/sec
[ 3] 8.0- 9.0 sec 460 KBytes 3.76 Mbits/sec
[ 3] 9.0-10.0 sec 571 KBytes 4.68 Mbits/sec
[ 3] 0.0-10.2 sec 19.2 MBytes 15.7 Mbits/sec
And the is from the PI2 over WIFI
TCP window size: 43.8 KByte (default)
[ 3] local 192.168.0.7 port 43820 connected with 192.168.0.2 port 5001
[ 3] 0.0- 1.0 sec 4.00 MBytes 33.6 Mbits/sec
[ 3] 1.0- 2.0 sec 5.00 MBytes 41.9 Mbits/sec
[ 3] 2.0- 3.0 sec 4.88 MBytes 40.9 Mbits/sec
[ 3] 3.0- 4.0 sec 5.25 MBytes 44.0 Mbits/sec
[ 3] 4.0- 5.0 sec 4.00 MBytes 33.6 Mbits/sec
[ 3] 5.0- 6.0 sec 4.88 MBytes 40.9 Mbits/sec
[ 3] 6.0- 7.0 sec 4.12 MBytes 34.6 Mbits/sec
[ 3] 7.0- 8.0 sec 896 KBytes 7.34 Mbits/sec
[ 3] 8.0- 9.0 sec 1.50 MBytes 12.6 Mbits/sec
[ 3] 9.0-10.0 sec 4.62 MBytes 38.8 Mbits/sec
[ 3] 0.0-10.0 sec 39.1 MBytes 32.8 Mbits/sec
I know there isn’t must in it but i could watch my HD films with my PI2 over WIFI
But can’t with the Vero4k
Vero4k is in the same place the PI2 was the only conclusion i can come up with that my router isn’t 5g only 2.4g and the VEro4k works better with a 5g router
I can run a wire up stairs for more tests but it would only be for that as my Partner would got nuts to fine a cable running from downstairs to our bedroom
the Vero4k is up to date and I’ve also tried SMB and fstab to the PI3 downstairs
I’m not sure what else I’m missing to be more helpful sorry
