Should not take that long. I suggest you upload debug enabled logs so that we can see what might be the issue. Also maybe check your network performance with iperf3.
There are many possible reasons, I would start with checking from an SSH session with showmount -e <IP of NAS>
Generally if you want to use this long term you might want to look into using fstab or autofs to mount the NAS.
