While my video startup isn’t noticable slower than before the update, I now get the ‘Playback Failed’ message after selecting most videos (from my server). Once I click OK I can then watch the ‘failed’ video.
Open a new thread and provide debug enabled logs.
Hello, and sorry for the late answer, not being home for some time !
Here are the outcome of the 2 commands
osmc@Vero4K:~$ ls -lah .kodi/temp/
total 1.8G
drwxr-xr-x 6 osmc osmc 4.0K Sep 5 14:41 .
drwxr-xr-x 10 osmc osmc 4.0K Oct 14 2020 …
-rw-r–r-- 1 osmc osmc 74M Apr 30 21:00 OSMCBACKUP_2021_04_30_20_11_28.tar.gz
-rw-r–r-- 1 osmc osmc 590M Aug 13 11:07 OSMCBACKUP_2021_08_13_10_58_17.tar.gz
-rw-r–r-- 1 osmc osmc 589M Sep 3 00:26 OSMCBACKUP_2021_09_03_00_17_13.tar.gz
-rw-r–r-- 1 osmc osmc 588M Sep 5 14:50 OSMCBACKUP_2021_09_05_14_41_15.tar.gz
drwxr-xr-x 2 osmc osmc 4.0K Sep 3 23:39 archive_cache
-rw-r–r-- 1 osmc osmc 12K Feb 2 2020 commoncache.db
srwxr-xr-x 1 osmc osmc 0 Sep 3 23:40 commoncache.socket
drwxr-xr-x 2 osmc osmc 4.0K Mar 3 2020 fonts
-rw-r–r-- 1 osmc osmc 747K Sep 15 13:18 kodi.log
-rw-r–r-- 1 osmc osmc 78K Sep 3 23:39 kodi.old.log
drwxr-xr-x 11 osmc osmc 4.0K Aug 11 07:00 scrapers
drwxr-xr-x 2 osmc osmc 4.0K Sep 3 22:31 temp
osmc@Vero4K:~$ df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 992M 0 992M 0% /dev
tmpfs 995M 33M 962M 4% /run
/dev/vero-nand/root 14G 7.8G 5.4G 60% /
tmpfs 995M 0 995M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 995M 0 995M 0% /sys/fs/cgroup
/dev/sda2 3.7T 1.5T 2.2T 41% /media/Expansion4T
/dev/sdc1 1.9T 1.5T 414G 78% /media/Elements2
/dev/sdb1 1.9T 1.1T 769G 59% /media/Expansion1
tmpfs 199M 0 199M 0% /run/user/1000
I do keep 3 OSMC backup files, rotating. The 4th and smaller/older one I am not sure why…
Thanks for helping, I will also check your answers in the other post mentioned by pinn73 and come back.
But I assume you write your tgatbackups to your NAS not the temporary folder, or?
That they remain in the temporary folder is because the backup script not working.
Suggest to run rm .kodi/temp/*
YES SOLVED!
I just remove the ./temp content as you recommended and everything is now fine, video starts almost instantly.
For the Backups, you are right I chose one of the local HDDs as destination in the settings. But I realize now that the most recent I have on HDD is Sep3, so the Sep5 one is missing, at least. And why the others even remain on local /temp I do not understand. There must be an issue with the backup script indeed. I will verify my backup settings, but any recommendation on this one is welcome
Many thanks for the help already !
It’s a know issue that will be fixed in the next update
Good to know!
I’ll check progress on this other one later then.
This has been an issue for a while now - see here Slow video start up - #24 by fzinken
