Hello,
- Kernel 4.9.269-44-osmc
- Kodi v20.3
- OSMC 2004.02-1
Using my Vero 4k, video is slow (audio is fine) on this show : HPI.S01E01.FRENCH.1080p.WEB.H264-FW.mkv (starting at 14:28:33.053 on the log file).
The same file is playing fine with VLC on my computer (same source, my nas, over the same network and switch).
All my other files are playing well on my Vero, so i guess this show files are responsible for this, maybe an issue on the encoding side ?
Maybe these lines explain it ?
2024-04-07 14:28:53.678 T:2940 debug <general>: ActiveAE::SyncStream - average error of 125.608908, start adjusting
2024-04-07 14:28:53.678 T:3039 debug <general>: CAEStreamParser::TrySyncAC3 - Unexpected stream type: 0 (wantEAC3dependent: true)
2024-04-07 14:28:53.738 T:2940 debug <general>: Skipped 1 duplicate messages..
2024-04-07 14:28:53.738 T:2940 debug <general>: ActiveAE::SyncStream - average error 29.608908 below threshold of 30.000000
2024-04-07 14:28:53.738 T:3039 debug <general>: CAEStreamParser::TrySyncAC3 - Unexpected stream type: 0 (wantEAC3dependent: true)
2024-04-07 14:28:56.716 T:2914 debug <general>: Skipped 90 duplicate messages..
2024-04-07 14:28:56.716 T:2914 debug <general>: ------ Window Deinit (DialogSeekBar.xml) ------
2024-04-07 14:28:56.749 T:3039 debug <general>: CAEStreamParser::TrySyncAC3 - Unexpected stream type: 0 (wantEAC3dependent: true)
2024-04-07 14:28:57.969 T:3034 debug <general>: Skipped 38 duplicate messages..
2024-04-07 14:28:57.969 T:3034 debug <general>: CPtsTracker: detected pattern of length 1: 20000.00, frameduration: 20000.000000
2024-04-07 14:28:57.988 T:3039 debug <general>: CAEStreamParser::TrySyncAC3 - Unexpected stream type: 0 (wantEAC3dependent: true)
2024-04-07 14:29:03.948 T:3039 info <general>: Skipped 186 duplicate messages..
2024-04-07 14:29:03.948 T:3039 info <general>: ProcessDecoderOutput: Changed max allowed Out-Of-Sync value to 42 ms due self-learning
2024-04-07 14:29:03.988 T:3039 debug <general>: CAEStreamParser::TrySyncAC3 - Unexpected stream type: 0 (wantEAC3dependent: true)
2024-04-07 14:29:11.839 T:3039 info <general>: Skipped 239 duplicate messages..
2024-04-07 14:29:11.839 T:3039 info <general>: CVideoPlayerAudio::Process - stream stalled
2024-04-07 14:29:11.846 T:3030 debug <general>: CVideoPlayer::HandlePlaySpeed - audio stream stalled, triggering re-sync
2024-04-07 14:29:11.846 T:3030 debug <general>: CVideoPlayer::FlushBuffers - flushing buffers
2024-04-07 14:29:11.848 T:3039 debug <general>: CDVDAudio::Flush - flush audio stream
2024-04-07 14:29:11.848 T:3039 debug <general>: CDVDAudio::Pause - pausing audio stream
File media infos are here : http://paste.osmc.tv/onuzavuhic.tex
OSMC logs are here : https://paste.osmc.tv/ifenuwumok (debug enabled during the play)
Any ideas ?
