Slow wifi with Edimax ew-7811Un (Raspberry Pi 2)
That looks like a good connection.
While your previous test showed already very likely the issue on he wifi maybe you can do a test with iperf against your notebook so that you clearly have LAN performance.
sudo apt-get install iperf3
On the iperf server side :
ID] Interval Transfer Bandwidth
[ 5] 0.00-1.00 sec 211 KBytes 1.73 Mbits/sec
[ 5] 1.00-2.00 sec 148 KBytes 1.22 Mbits/sec
[ 5] 2.00-3.00 sec 45.2 KBytes 371 Kbits/sec
[ 5] 3.00-4.00 sec 41.0 KBytes 336 Kbits/sec
[ 5] 4.00-5.00 sec 122 KBytes 996 Kbits/sec
[ 5] 5.00-6.00 sec 208 KBytes 1.70 Mbits/sec
[ 5] 6.00-7.00 sec 259 KBytes 2.12 Mbits/sec
[ 5] 7.00-8.00 sec 230 KBytes 1.89 Mbits/sec
[ 5] 8.00-9.00 sec 228 KBytes 1.87 Mbits/sec
[ 5] 9.00-10.00 sec 267 KBytes 2.19 Mbits/sec
[ 5] 10.00-10.13 sec 39.6 KBytes 2.52 Mbits/sec
[ ID] Interval Transfer Bandwidth Retr
[ 5] 0.00-10.13 sec 1.85 MBytes 1.54 Mbits/sec 0 sender
[ 5] 0.00-10.13 sec 1.76 MBytes 1.45 Mbits/sec receiver
Client side (my wifi rasp)
[ 4] 0.00-1.00 sec 303 KBytes 2.48 Mbits/sec 0 48.1 KBytes
[ 4] 1.00-2.00 sec 139 KBytes 1.14 Mbits/sec 0 48.1 KBytes
[ 4] 2.00-3.00 sec 33.9 KBytes 278 Kbits/sec 0 48.1 KBytes
[ 4] 3.00-4.00 sec 65.0 KBytes 533 Kbits/sec 0 48.1 KBytes
[ 4] 4.00-5.00 sec 102 KBytes 834 Kbits/sec 0 48.1 KBytes
[ 4] 5.00-6.00 sec 199 KBytes 1.63 Mbits/sec 0 48.1 KBytes
[ 4] 6.00-7.00 sec 331 KBytes 2.71 Mbits/sec 0 76.4 KBytes
[ 4] 7.00-8.00 sec 206 KBytes 1.69 Mbits/sec 0 76.4 KBytes
[ 4] 8.00-9.00 sec 208 KBytes 1.70 Mbits/sec 0 76.4 KBytes
[ 4] 9.00-10.00 sec 313 KBytes 2.56 Mbits/sec 0 76.4 KBytes
[ 4] 0.00-10.00 sec 1.85 MBytes 1.56 Mbits/sec 0 sender
[ 4] 0.00-10.00 sec 1.76 MBytes 1.47 Mbits/sec receiver
EDIT : the server was a wired connected rpi 2, the client my wifi trouble rpi. I also tried with a rpi 3 wired as the client, and the bandwith is live 85Mbits/sec
OK that really confirms your issue.
I currently don’t have access to my rpi that has that wireless adapter connected to crosscheck.
Did you tried the RPi3 internal wireless to see if that performs well on your wifi?
From the rpi3 wireless connected :
[ 4] 0.00-1.00 sec 3.06 MBytes 25.7 Mbits/sec 0 158 KBytes
[ 4] 1.00-2.00 sec 5.36 MBytes 45.0 Mbits/sec 0 229 KBytes
[ 4] 2.00-3.00 sec 4.81 MBytes 40.4 Mbits/sec 0 286 KBytes
[ 4] 3.00-4.00 sec 5.46 MBytes 45.8 Mbits/sec 0 348 KBytes
[ 4] 4.00-5.00 sec 5.08 MBytes 42.7 Mbits/sec 0 389 KBytes
[ 4] 5.00-6.00 sec 5.67 MBytes 47.5 Mbits/sec 0 428 KBytes
[ 4] 6.00-7.00 sec 905 KBytes 7.42 Mbits/sec 0 428 KBytes
[ 4] 7.00-8.00 sec 2.76 MBytes 23.2 Mbits/sec 0 451 KBytes
[ 4] 8.00-9.00 sec 993 KBytes 8.13 Mbits/sec 0 451 KBytes
[ 4] 9.00-10.00 sec 1.28 MBytes 10.8 Mbits/sec 0 451 KBytes
[ 4] 0.00-10.00 sec 35.3 MBytes 29.7 Mbits/sec 0 sender
[ 4] 0.00-10.00 sec 34.7 MBytes 29.1 Mbits/sec receiver
Very clear sign. I will check when I get access to my adapter again (can be several days later).
Did you see anything in the logs that could give a hint for the problem?
grab-logs -JK
Nothing seems strange to me, but I’m not an expert : http://paste.osmc.io/lanawujopo
Thanks for your help.
I solved it by buying an another wifi dongle : https://www.amazon.fr/gp/product/B00GMY40T0/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Everything is okay, with a download debit at 45Mbits/s !
I’m facing the exact same issue with this dongle and a RPI2. I guess it has to do with the kernel version / a parameter that was introduced in newer version of the kernel because I did not get issues with Raspbian Jessie before.
I also get less than 1 Mbit/s when testing with iperf.
