I want to play video from my Windows 7 PC in Kodi. Unfortunately Samba (SMB) menu for new video source cannot find any sharings. I made static mount in OSMC console - now I have the PC directory mounted as /mnt/movies. Unfortunately this has side effects - the PC cannot sleep, it wakes up after entering sleep mode. Is there a way to access SMB share from Kodi UI?
You need to browse to:
root filesystem > mnt > movies
Thanks Tom.
Yes, it works with /mnt/movies. But the problem is with static mount - it seems RPi samba client sends packets to Windows 7 and wakes it up. Since I added this mount, Win7 PC cannot enter in sleep mode.
Please provide the fstab entry
Thanks Tom.
