I’m getting an Error “connection timed out” followed by Remote Share “couldn’t connect to network server”
Below are my logs:
http://paste.osmc.io/abelipodah
Any ideas?
Thanks.
Below are my logs:
Any ideas?
Thanks.
To add some more information…
It’s an intermittent problem. After manually prompting OSMC to scan for new content, it might start and continue successfully for a while and then stop, before the library has been fully scanned. Attempts to restart the scan might be successful. Same applies to playing media content; sometimes it starts, sometimes it doesn’t, but most of the time it doesn’t.
Your WiFi connection is repeatedly disconnecting, can you try with a network cable?
