If my memory serves me correctly, the autoshares work without sudo smbpasswd -a osmc.
But if you make your own shares you need to have added osmc as a smbuser as well, to get it to work. Now it’s been a while since i fiddle with this last, since it’s part of my auto customization script i run at second boot. =)
Thanks for your Tipps!!
I have activated the Samba server on the OSMC in the “Services” settings of the OSMC menu.
I want to connect from my Windows PC to “\192.168.x.x\media”. A password window appears with the login options (see attachment).
Then the system doesn’t accept any of my passwords!?
I have already tried changing the Samba password:
sudo smbpasswd -a password1, but this password is not accepted either.
Do you have any other tips on what I can try?
smbpasswd adds a user and ask for password for that user
Now you might be thinking, osmc allready exist in system, but smbpasswd is it’s own user and password db. So you could make a smbpasswd -a kids, and in /etc/samba/smb-shares.conf create a share:
[KidsTV]
browsable = yes
read only = yes
valid users = kids
path = /mnt/kidstv-hdd
comment = TV shows for kids
Now this is just fictive share, make sure the path exist.
Well, it “could be” especially if you don’t have the same password on both users. else you could tell windwos smb client to use the osmc user of the server, I know i have done that before, just unsure from the top of my head how to. Using net-command in windows CLI, I think you could do user@serverip there by stop windows authenticating with local osmc password. But as I said, been a while since I played with this.
