Yep, I’m a bit puzzled about it. I’ve a shared folder in a Windows 10 machine. If I reboot OSMC and i try to access the shared folder it says: ‘No route to host’. However, if I go to my Windows 10 machine, I open a SSH session, then I close it and I retry the connection it works. wtf? Maybe it isn’t related to OSMC, but could someone know what’s going on with this?
Sounds like a firewall or networking issue. Do the OSMC device (Pi, Vero, …?) and the Windows 10 machine get told their IP, DNS, and gateway by a DHCP?
Did you specify a host name or an IP in /etc/fstab? Or do you do use userland-based mounting?
If you’re unsure about answering, please upload a log.
Well A full logs including dmesg and journal would most likely tell us more.
Alternatively you might want to try autofs instead of the build in smb client
