SMB shares on MacOS not working with Vero4k using /etc/fstab
I have moved my media libraries to my Mac and I want to share them via SMB to my various Vero boxes.
Here is the output from smbclient on my Vero:
osmc@KodiKave:/mnt$ smbclient -L 10.7.10.29 -U kodi
Enter WORKGROUP\kodi's password:
	Sharename       Type      Comment
	Concerts        Disk
	IPC$            IPC
	kodi’s Public Folder Disk
	Movies          Disk
	Music           Disk
	TVShows         Disk
	kodi            Disk
SMB1 disabled -- no workgroup available
osmc@KodiKave:/mnt$
I then added the /etc/fstab entry as follows:
osmc@KodiKave:/mnt$ sudo cat /etc/fstab
# rootfs is not mounted in fstab as we do it via initramfs. Uncomment for remount (slower boot)
#/dev/vero-nand/root  /    ext4      defaults,noatime    0   0
//10.7.10.29/Movies /mnt/ServerMovies cifs x-systemd.automount,noauto,rw,iocharset=utf8,credentials=/home/osmc/.credentials,uid=osmc,gid=osmc,file_mode=0770,dir_mode=0770,vers=2.0 0 0
osmc@KodiKave:/mnt$
When I enter sudo mount -a, it returns to the command prompt.
When I try to cd into /mnt/ServerMovies, I get:
osmc@KodiKave:/mnt$ ls
ServerMovies
osmc@KodiKave:/mnt$ cd ServerMovies
-bash: cd: ServerMovies: No such device
osmc@KodiKave:/mnt$
Thank you.
I might be old fashion, but if I’m going to mount from fstab, I make sure that the mount point exists before trying.
That is make sure there is no mount, then: sudo mkdir /mnt/ServerMovies
you might want to chmod or chown the folder, but make sure the mountpoint exist first.
I removed the existing directories, created it manually and then tried mounting from fstab again.
Same issue:
osmc@KodiKave:/mnt$ ls -l
total 0
drwxr-xr-x 2 root root 0 Oct 29 13:45 Server-Movies
osmc@KodiKave:/mnt$ cd Server-Movies
-bash: cd: Server-Movies: No such device
osmc@KodiKave:/mnt$
The fstab entry was also changed to ‘Server-Movies’.
I figured out what was wrong.
I had formatted by credentials file like:
username=<username>
password=<password>
It should have been:
username=username
password=password
so the brackets is what stopped the ‘cd’ command from working. I can now see the files on the OSX share.
On with the rest of the config.
Those brackets normally indicate that this part is to be replaced with your customised content
