So Finally got the Vero4k+ a few days ago and now having a bit of difficultly with sharing some larger bit rate files. In this case about 100Mb/s. For some reason when setting up smb I had to use smbv1 as all the others failed to play any files although it would let me browse the directories. I also do not have a NAS just a mac running Catalina 10.15.7 with a few drives connected to it. It’s a hackintosh but I fail to see how that would matter for this. Anyways is SMB v2 or v3 any faster and if so I wonder why it wont connect with v2 or v3. Also the mac and vero are on Gb ethernet so that’s not the bottleneck. Any ideas? Thanks
Edit: It will play these files but it buffers for a while and stutters and has to buffer again shortly after playback begins.
I will give the MTU setting a shot and yes I am set to advanced or expert. Also I am not sure if it’s the problem is with smb2 or 3 as neither seem to work. I also have seen the autofs page but it’s a bit above my head for now. Also from what I have read my mac should support all 3 versions. Keyword should.
enable component-specific logging for the SMB library
enable event logging and notification event logging
reproduce the issue
Hopefully I will have time later tonight to submit some logs as well as wrap my head around using the autofs command. Thankfully this issue is very rare but one I would like to fix. It’s raw gopro files so almost 4g for 8mins not something I often watch on the big tv however I would like to from time to time.
Could you also put one of these gopro files on a USB stick and try to play it with the stick inserted into the Vero? If it is the same issue, it’s not realted to the network/smb/etc. at all but soemthing special with the gopro file format like that issue from 2018.
I will however I highly doubt that is the issue as once the file has buffered a bit it plays perfectly until the buffered data is eaten up. Looking at the network meter on the mac I can see throughput is just a bit below the bit rate of the file.
I don’t know much about Apple stuff, but Unix systems should probably use the native NFS for network files, not CIFS. NFS tends to work better for OSMC, IME,
OR
just run a DLNA server on the Mac and use OSMC as a DLNA client+renderer?
I do both, this removes all the funky things that MSFT does with the CIFS stuff and all the Apache-samba guys attempted responses from our concern.
There are a number of good DLNA servers for Linux. I’d assume they work on Apple too.
I have to agee on this. Never, ever mount a network share with Kodi. I haven’t tested what Kodi does and honestly I don’t really care at this point, but it was more than 10x slower than just mounting it via fstab.
