I need some help figuring out my sound output setup.
Before I switched to the Pi 2, I had this exact same set-up and everything worked fine, on a PC set-up as a media center.
My connection is as follows, all via HDMI: Pi 2 > Smart TV > 5.1 receiver
The reason I want this set-up is I don’t always use my 5.1 system, so I don’t want to have to turn it on/off every time I use OSMC. When the receiver is off, I just get 2 channel stereo output.
The problem is that if I set-up audio support to anything other than 2.0 channels in OSMC, it will drop channels in 5.1 movies and I don’t hear voices, for example.
What would be the proper configuration to get this setup working correctly, any ideas?
