Hi together,
I know that there are a lot of discussions out there and I am looking now for a very long time for a solution but non of the solutions worked so far for me. Here it is:
I run OSMC in the latest version on a Rasp 3B. Connecting to my shares directly via KODI does not work properly (not all files are detected) thus I added the shares in the fstab as follows:
//192.168.x.yyy/music /media/Musik cifs auto 0 0
This leads to the fact that OSMC is asking to enter a password during boot despite not password is set at all (public share).
Pressing works and after that the share is properly connected. Well, now I do not want to press a lot of returns during boot…
- Tried to work with “guest” instead of auto;
- tried to add added very different ways of password setting (e.g. credentials=/home/osmc/.smbcredentials,uid=osmc,gid=osmc,_netdev,x-systemd.automount 0 0) with or without a password in the smbcredentials
and so on and forth… Nothing worked, at the end I ended up with
“[FAILED] Failed to mount /…/… See systemctl status ... for details [DEPEND] Dependency failed for remote file systems.”
If I access than the system via SSH and start “mount -a”, all shares are conncected.
What can I do to have the shares mounted automatically?
Thanks, Tabaluga
