Ok, I have a Raspberry Pi 2B+
I took a look at my /boot/config.txt and it looks completely different from what I’m used to. Is there a guide on the new syntax (for me, at least)?
Thanks very much!
Thanks very much!
config.txt anymore but user changes go to config-user.txtThanks, @fzinken
I saw the include and kinda guessed. I’ll check it out.
I’m trying to install RetroPie and it is complaining about an experimental GL driver which can be deactivated from raspi-config, since OSMC doesn’t use it. I’m kinda lost.
Thanks so far!
Changing that device tree will cause issues and is not recommended.
That’s what I thought.
RetroPie is running OK. The system is kinda stable, though. I feel like it’s a matter of moving to python3;
