To expand on this, use Gparted from a different Linux system, not from within OSMC. If you don’t have a Linux system you can use a Virtualbox VM or boot from a Linux live usb, see pendrivelinux.com for a wide variety of choices
cool thanks. I just tried the live gparted boot cd and it kernel panicked and nearly killed my win10 laptop from booting(back now just about!) ended up using SystemRescue - System Rescue Homepage
to run gparted via startx… worked beautifully!
cheers
Did you get the solution?
Can you expand the file system within osmc itself, or you have to take help of another operating systerm to resize your memory card?
I see you started a new thread and answered ther.
Yes I did, as this thread marked as [Solved]. Please follow this link . where you can answer in new thread.
