Hi! I’m wandering how to configure OSMC (or may be it is kodi option) to disable playback loopping.
After movie end I don’t want movie start playing again from start, I just want it stopped and back to main menu. how to do that?
By default, i thinks, the loops it’s disabled… you have activated it.
Try to look here:
When you stay on file list… press left and open menù. After check the “Playlist”. Re-Open the left menù and loop option it’s present here.
Thanks, but there is no “Playlist” in “left” menu. BTW I can’t find “playlist” nowhere…
Yes… you can find the playlist when you are on a folder whit some video…
