is there a way to use I2C
SMBUS
without Sudo via python in OSMC?
Thanks T
SMBUS
Thanks T
Some udev rules may help.
Which /dev nodes are you using?
for i2c
using /dev/i2c-1
self.bus = SMBus(self._port)
thanks
You can change the permissions with a udev rule or run the script with privileges
ok thanks will try
sudo nano /lib/udev/rules.d/60-i2c-tools.rules
KERNEL==“i2c-0” , GROUP=“i2c”, MODE=“0660”
KERNEL==“i2c-[1-9]*”, GROUP=“i2c”, MODE=“0666”
is working
solved thx
