[The solution was to use a different USB, 32GB in my case.]
Hello.
I am new to the world of OSMC.
I have heard about it from a video, and I decided to install it on my Apple TV, 1st gen.
Straight to the point.
After flashing the image into my flash drive, I plugged it into the only USB port it has and it went well, until it showed “Installation Failed: Could not mount bootfs”.
I have tried redownloading and reflashing, but it’s always the same.
The model is “A1218”, one optical audio port, one HDMI, one ETHERNET, component ports and a single USB port.
The version of OSMC is 2017.08-1-HDD.
I hope someone can help me on this problem.
I will answer all questions as fast as I can.
