Hi all,
Last week -probably after a reboot which may have booted latest kernel?- my IQAudio Dac+ stopped working on OSMC. I did the following steps:
Downloaded IQAudio test image and verified that the DAC is functional
SSHed into OSMC and run apt-get update && apt-get dist-upgrade and I have no missing upgrades.
aplay -l does not list the card.
I verified that boot/config.txt has
dtoverlay=iqaudio-dacplus-overlay
dtparam=audio=on -
I re-configured the DAC using the MyOSMC app
I can’t get it to work. Kernel messages have some interesting output with failure traces which I attach bellow.
This is a RPi2 with OSMC powered by a official RPi power supply.
I’d appreciate any helping tips to get this working again. Thanks!
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 4.9.29-9-osmc (root@vero3-db) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Sat Jul 29 01:44:42 UTC 2017
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 80e6edc0, node_mem_map add64000
[ 0.000000] Normal zone: 1692 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 15 pages/cpu @aefa4000 s30592 r8192 d22656 u61440
[ 0.000000] pcpu-alloc: s30592 r8192 d22656 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[ 0.000000] Kernel command line: bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 739348K/770048K available (8192K kernel code, 486K rwdata, 1984K rodata, 2048K init, 785K bss, 22508K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xaf800000 - 0xff800000 (1280 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80900000 (9184 kB)
.init : 0x80c00000 - 0x80e00000 (2048 kB)
.data : 0x80e00000 - 0x80e79b28 ( 487 kB)
.bss : 0x80e7b000 - 0x80f3f564 ( 786 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000012] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000029] Switching to timer-based delay loop, resolution 52ns
[ 0.000344] Console: colour dummy device 80x30
[ 0.000372] console [tty0] enabled
[ 0.000400] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000423] pid_max: default: 32768 minimum: 301
[ 0.000800] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000814] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002096] Disabling cpuset control group subsystem
[ 0.002296] CPU: Testing write buffer coherency: ok
[ 0.002363] ftrace: allocating 20363 entries in 60 pages
[ 0.051381] CPU0: update cpu_capacity 1024
[ 0.051406] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.051480] Setting up static identity map for 0x100000 - 0x100034
[ 0.221519] CPU1: update cpu_capacity 1024
[ 0.221531] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.291564] CPU2: update cpu_capacity 1024
[ 0.291574] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.361677] CPU3: update cpu_capacity 1024
[ 0.361687] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.361798] Brought up 4 CPUs
[ 0.361815] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.361821] CPU: All CPU(s) started in HYP mode.
[ 0.361826] CPU: Virtualization extensions available.
[ 0.362901] devtmpfs: initialized
[ 0.375507] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.375914] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.375942] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.376725] pinctrl core: initialized pinctrl subsystem
[ 0.378013] NET: Registered protocol family 16
[ 0.380288] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.421583] cpuidle: using governor ladder
[ 0.451613] cpuidle: using governor menu
[ 0.451772] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.451782] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.451966] Serial: AMBA PL011 UART driver
[ 0.454366] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.543359] bcm2835-dma 3f007000.dma: DMA legacy API manager at af80f000, dmachans=0x1
[ 0.545581] SCSI subsystem initialized
[ 0.545786] usbcore: registered new interface driver usbfs
[ 0.545880] usbcore: registered new interface driver hub
[ 0.546028] usbcore: registered new device driver usb
[ 0.551935] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-07-22 00:01
[ 0.553339] clocksource: Switched to clocksource arch_sys_counter
[ 0.607364] VFS: Disk quotas dquot_6.6.0
[ 0.607472] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.607760] FS-Cache: Loaded
[ 0.608116] CacheFiles: Loaded
[ 0.623919] NET: Registered protocol family 2
[ 0.625138] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.625269] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.625458] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.625572] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.625632] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.625953] NET: Registered protocol family 1
[ 0.626611] RPC: Registered named UNIX socket transport module.
[ 0.626620] RPC: Registered udp transport module.
[ 0.626626] RPC: Registered tcp transport module.
[ 0.626632] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.739539] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.741129] audit: initializing netlink subsys (disabled)
[ 0.741203] audit: type=2000 audit(0.719:1): initialized
[ 0.742726] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.761663] FS-Cache: Netfs 'nfs' registered for caching
[ 0.763020] NFS: Registering the id_resolver key type
[ 0.763060] Key type id_resolver registered
[ 0.763067] Key type id_legacy registered
[ 0.769728] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.769902] io scheduler noop registered
[ 0.770535] io scheduler bfq registered (default)
[ 0.770543] BFQ I/O-scheduler: v8r7
[ 0.776224] BCM2708FB: allocated DMA memory ee500000
[ 0.776263] BCM2708FB: allocated DMA channel 0 @ af80f000
[ 0.838265] Console: switching to colour frame buffer device 240x67
[ 0.879182] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.879317] vc-cma: Videocore CMA driver
[ 0.879327] vc-cma: vc_cma_base = 0x00000000
[ 0.879335] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.879342] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.879616] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.900907] brd: module loaded
[ 0.912751] loop: module loaded
[ 0.912768] Loading iSCSI transport class v2.0-870.
[ 0.913715] usbcore: registered new interface driver smsc95xx
[ 0.913741] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.141974] Core Release: 2.80a
[ 1.141990] Setting default values for core params
[ 1.142013] Finished setting default values for core params
[ 1.342473] Using Buffer DMA mode
[ 1.342484] Periodic Transfer Interrupt Enhancement - disabled
[ 1.342490] Multiprocessor Interrupt Enhancement - disabled
[ 1.342499] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.342513] Dedicated Tx FIFOs mode
[ 1.343010] WARN::dwc_otg_hcd_init:1034: FIQ DMA bounce buffers: virt = 0xae514000 dma = 0xee514000 len=9024
[ 1.343048] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 1.343058] dwc_otg: Microframe scheduler enabled
[ 1.343128] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x806d589c
[ 1.343142] WARN::hcd_init_fiq:460: FIQ ASM at 0x806d5c0c length 36
[ 1.343157] WARN::hcd_init_fiq:486: MPHI regs_base at 0xaf87a000
[ 1.343235] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.343288] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.343389] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.343441] Init: Port Power? op_state=1
[ 1.343448] Init: Power Port (0)
[ 1.343765] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.343779] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.343790] usb usb1: Product: DWC OTG Controller
[ 1.343801] usb usb1: Manufacturer: Linux 4.9.29-9-osmc dwc_otg_hcd
[ 1.343811] usb usb1: SerialNumber: 3f980000.usb
[ 1.344926] hub 1-0:1.0: USB hub found
[ 1.344995] hub 1-0:1.0: 1 port detected
[ 1.345827] dwc_otg: FIQ enabled
[ 1.345834] dwc_otg: NAK holdoff enabled
[ 1.345840] dwc_otg: FIQ split-transaction FSM enabled
[ 1.345859] Module dwc_common_port init
[ 1.346298] usbcore: registered new interface driver usb-storage
[ 1.346663] mousedev: PS/2 mouse device common for all mice
[ 1.347128] usbcore: registered new interface driver usbtouchscreen
[ 1.347866] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 1.348236] bcm2835-cpufreq: min=600000 max=900000
[ 1.349634] sdhci: Secure Digital Host Controller Interface driver
[ 1.349640] sdhci: Copyright(c) Pierre Ossman
[ 1.349916] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[ 1.350102] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.350723] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.350849] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.351003] usbcore: registered new interface driver usbhid
[ 1.351008] usbhid: USB HID core driver
[ 1.351795] vchiq: vchiq_init_state: slot_zero = 0xae580000, is_master = 0
[ 1.353760] Initializing XFRM netlink socket
[ 1.353802] NET: Registered protocol family 17
[ 1.353928] Key type dns_resolver registered
[ 1.354033] Registering SWP/SWPB emulation handler
[ 1.354778] registered taskstats version 1
[ 1.356315] Key type encrypted registered
[ 1.356631] vc-sm: Videocore shared memory driver
[ 1.356642] [vc_sm_connected_init]: start
[ 1.362925] [vc_sm_connected_init]: end - returning 0
[ 1.367398] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 1.369064] sdhost: log_buf @ ae513000 (ee513000)
[ 1.443361] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.443530] of_cfs_init
[ 1.443640] of_cfs_init: OK
[ 1.466170] Freeing unused kernel memory: 2048K (80c00000 - 80e00000)
[ 1.511478] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.513701] mmc0: new high speed SDHC card at address 0007
[ 1.514554] mmcblk0: mmc0:0007 SD8GB 7.42 GiB
[ 1.526851] mmcblk0: p1 p2
[ 1.573580] Indeed it is in host mode hprt0 = 00021501
[ 1.662147] random: fast init done
[ 1.773380] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.773540] Indeed it is in host mode hprt0 = 00001101
[ 2.003646] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.003656] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.004821] hub 1-1:1.0: USB hub found
[ 2.004907] hub 1-1:1.0: 5 ports detected
[ 2.104684] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.116093] fsck: E2fsck run: /bin/e2fsck -p -C 0 /dev/mmcblk0p2
[ 2.116335] fsck: Filesystem UUID: 8fd25a66-63af-426f-9093-9847effcf1e7
[ 2.116587] fsck: /dev/mmcblk0p2: clean, 64436/471424 files, 923131/1882880 blocks
[ 2.323404] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.453752] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.453760] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.456628] smsc95xx v1.0.5
[ 2.557060] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:b7:53:76
[ 4.087933] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 4.088284] systemd[1]: Detected architecture 'arm'.
[ 4.156159] NET: Registered protocol family 10
[ 4.157903] systemd[1]: Inserted module 'ipv6'
[ 4.171200] systemd[1]: Set hostname to <xbmc>.
[ 4.566773] systemd[1]: Cannot add dependency job for unit syncthing-inotify@osmc.service, ignoring: Unit syncthing-inotify@osmc.service failed to load: No such file or directory.
[ 4.567175] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 4.567437] systemd[1]: Found ordering cycle on basic.target/start
[ 4.567456] systemd[1]: Found dependency on sysinit.target/start
[ 4.567472] systemd[1]: Found dependency on kbd.service/start
[ 4.567485] systemd[1]: Found dependency on remote-fs.target/start
[ 4.749874] fuse init (API version 7.26)
[ 4.948145] systemd-udevd[198]: starting version 215
[ 5.845534] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 6.277608] Unable to handle kernel paging request at virtual address 31ba9988
[ 6.277614] Unable to handle kernel paging request at virtual address 31b64988
[ 6.277619] Unable to handle kernel paging request at virtual address 31b1f988
[ 6.277623] pgd = ad0c4000
[ 6.277637] pgd = adbd0000
[ 6.277646] [31b64988] *pgd=00000000
[ 6.277649] [31b1f988] *pgd=00000000
[ 6.277660] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[ 6.277697] Modules linked in: snd_compress snd_bcm2835 snd_pcm_dmaengine snd_pcm snd_timer snd bcm2835_thermal i2c_bcm2835 bcm2835_gpiomem fixed uio_pdrv_genirq uio fuse ipv6
[ 6.277708] CPU: 3 PID: 227 Comm: systemd-udevd Not tainted 4.9.29-9-osmc #1
[ 6.277710] Hardware name: BCM2835
[ 6.277715] task: ad06d880 task.stack: acdc4000
[ 6.277731] PC is at strlen+0xc/0x38
[ 6.277744] LR is at load_module+0xe8c/0x2cb8
[ 6.277752] pc : [<8055ebf8>] lr : [<801d34bc>] psr: 20000013
sp : acdc5e58 ip : acdc5e68 fp : acdc5e64
[ 6.277756] r10: 00000003 r9 : 0000001a r8 : b1b135c0
[ 6.277760] r7 : b1b17496 r6 : b1af0000 r5 : acdc5f3c r4 : 0000000a
[ 6.277765] r3 : 80000000 r2 : 00000073 r1 : 00000000 r0 : 31b1f988
[ 6.277771] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 6.277776] Control: 10c5387d Table: 2dbd006a DAC: 00000055
[ 6.277780] Process systemd-udevd (pid: 227, stack limit = 0xacdc4210)
[ 6.277784] Stack: (0xacdc5e58 to 0xacdc6000)
[ 6.277790] 5e40: acdc5f14 acdc5e68
[ 6.277799] 5e60: 801d34bc 8055ebf8 ab4deff8 00000001 00000000 b1af0000 acdc5ecc acdc5e88
[ 6.277808] 5e80: 802e8038 ffffffff 76d909f8 b1b3372c b1b33704 0000085a 00000000 acdc5ee0
[ 6.277816] 5ea0: accafa40 acdc4000 acdc5f2c 80a4c728 00000001 00000000 80ac8b00 80abcfcc
[ 6.277824] 5ec0: acdc5f14 acdc5ed0 802f2e84 802e7eb0 acdc5f30 ad14e780 00043754 00000000
[ 6.277832] 5ee0: 00043754 00000000 acdc5f34 00000000 0000000f 76d909f8 0000017b 7fffffff
[ 6.277841] 5f00: 00000000 00000000 acdc5fa4 acdc5f18 801d54f0 801d263c 7fffffff 00000000
[ 6.277849] 5f20: 00000003 8028dab0 acdc5f74 b1af0000 00043754 00000000 00000002 b1af0000
[ 6.277857] 5f40: 00043754 b1b32ee4 b1b171c3 b1b1f988 00000000 00000000 00000000 00000000
[ 6.277864] 5f60: 00000000 00000000 00000034 00000035 00000029 0000002d 00000014 00000000
[ 6.277873] 5f80: 0000017b 01309648 7efc9024 08dbdc00 8010f808 acdc4000 00000000 acdc5fa8
[ 6.277883] 5fa0: 8010f640 801d5448 01309648 7efc9024 0000000f 76d909f8 00000000 01309ad8
[ 6.277891] 5fc0: 01309648 7efc9024 08dbdc00 0000017b 00020000 00037f78 00050048 0130d888
[ 6.277900] 5fe0: 7efc8f00 7efc8ef0 76d8ac4b 76e95a42 60010030 0000000f 00000000 00000000
[ 6.277931] [<8055ebf8>] (strlen) from [<801d34bc>] (load_module+0xe8c/0x2cb8)
[ 6.277946] [<801d34bc>] (load_module) from [<801d54f0>] (SyS_finit_module+0xb4/0xcc)
[ 6.277962] [<801d54f0>] (SyS_finit_module) from [<8010f640>] (ret_fast_syscall+0x0/0x1c)
[ 6.277973] Code: e89da800 e1a0c00d e92dd800 e24cb004 (e5d02000)
[ 6.277979] ---[ end trace 34ebc041087254cf ]---
[ 6.277982] Internal error: Oops: 5 [#2] PREEMPT SMP ARM
[ 6.278017] Modules linked in: snd_compress snd_bcm2835 snd_pcm_dmaengine snd_pcm snd_timer snd bcm2835_thermal i2c_bcm2835 bcm2835_gpiomem fixed uio_pdrv_genirq uio fuse ipv6
[ 6.278025] CPU: 1 PID: 225 Comm: systemd-udevd Tainted: G D 4.9.29-9-osmc #1
[ 6.278028] Hardware name: BCM2835
[ 6.278032] task: ad06bb00 task.stack: ad3ce000
[ 6.278039] PC is at strlen+0xc/0x38
[ 6.278046] LR is at load_module+0xe8c/0x2cb8
[ 6.278053] pc : [<8055ebf8>] lr : [<801d34bc>] psr: 200f0013
sp : ad3cfe58 ip : ad3cfe68 fp : ad3cfe64
[ 6.278056] r10: 00000003 r9 : 0000001a r8 : b1b585c0
[ 6.278061] r7 : b1b5c496 r6 : b1b35000 r5 : ad3cff3c r4 : 0000000a
[ 6.278065] r3 : 80000000 r2 : 00000073 r1 : 00000000 r0 : 31b64988
[ 6.278070] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 6.278076] Control: 10c5387d Table: 2d0c406a DAC: 00000055
[ 6.278080] Process systemd-udevd (pid: 225, stack limit = 0xad3ce210)
[ 6.278083] Stack: (0xad3cfe58 to 0xad3d0000)
[ 6.278091] fe40: ad3cff14 ad3cfe68
[ 6.278099] fe60: 801d34bc 8055ebf8 ab4deff8 00000001 00000000 b1b35000 ad3cfecc ad3cfe88
[ 6.278109] fe80: 802e8038 ffffffff 76d909f8 b1b7872c b1b78704 0000085a 00000000 ad3cfee0
[ 6.278117] fea0: accaf180 ad3ce000 ad3cff2c 80a4c728 00000001 00000000 80ac8b00 80abcfcc
[ 6.278126] fec0: ad3cff14 ad3cfed0 802f2e84 802e7eb0 ad3cff30 adbd6780 00043754 00000000
[ 6.278135] fee0: 00043754 00000000 ad3cff34 00000000 0000000f 76d909f8 0000017b 7fffffff
[ 6.278143] ff00: 00000000 00000000 ad3cffa4 ad3cff18 801d54f0 801d263c 7fffffff 00000000
[ 6.278152] ff20: 00000003 8028dab0 ad3cff74 b1b35000 00043754 00000000 00000002 b1b35000
[ 6.278160] ff40: 00043754 b1b77ee4 b1b5c1c3 b1b64988 00000000 00000000 00000000 00000000
[ 6.278167] ff60: 00000000 00000000 00000034 00000035 00000029 0000002d 00000014 00000000
[ 6.278176] ff80: 0000017b 01309648 7efc9024 08dbdc00 8010f808 ad3ce000 00000000 ad3cffa8
[ 6.278185] ffa0: 8010f640 801d5448 01309648 7efc9024 0000000f 76d909f8 00000000 01309ad8
[ 6.278194] ffc0: 01309648 7efc9024 08dbdc00 0000017b 00020000 00037f78 00050048 01318cd8
[ 6.278202] ffe0: 7efc8f00 7efc8ef0 76d8ac4b 76e95a42 60010030 0000000f 00000000 00000000
[ 6.278219] [<8055ebf8>] (strlen) from [<801d34bc>] (load_module+0xe8c/0x2cb8)
[ 6.278231] [<801d34bc>] (load_module) from [<801d54f0>] (SyS_finit_module+0xb4/0xcc)
[ 6.278244] [<801d54f0>] (SyS_finit_module) from [<8010f640>] (ret_fast_syscall+0x0/0x1c)
[ 6.278253] Code: e89da800 e1a0c00d e92dd800 e24cb004 (e5d02000)
[ 6.278257] ---[ end trace 34ebc041087254d0 ]---
[ 6.376657] pgd = acdb0000
[ 6.384049] [31ba9988] *pgd=00000000
[ 6.391327] Internal error: Oops: 5 [#3] PREEMPT SMP ARM
[ 6.398589] Modules linked in: snd_compress snd_bcm2835 snd_pcm_dmaengine snd_pcm snd_timer snd bcm2835_thermal i2c_bcm2835 bcm2835_gpiomem fixed uio_pdrv_genirq uio fuse ipv6
[ 6.406269] CPU: 3 PID: 229 Comm: systemd-udevd Tainted: G D 4.9.29-9-osmc #1
[ 6.413876] Hardware name: BCM2835
[ 6.421416] task: acd7e740 task.stack: ad090000
[ 6.428984] PC is at strlen+0xc/0x38
[ 6.436534] LR is at load_module+0xe8c/0x2cb8
[ 6.444008] pc : [<8055ebf8>] lr : [<801d34bc>] psr: 200f0013
sp : ad091e58 ip : ad091e68 fp : ad091e64
[ 6.459001] r10: 00000003 r9 : 0000001a r8 : b1b9d5c0
[ 6.466453] r7 : b1ba1496 r6 : b1b7a000 r5 : ad091f3c r4 : 0000000a
[ 6.473905] r3 : 80000000 r2 : 00000073 r1 : 00000000 r0 : 31ba9988
[ 6.481367] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 6.488821] Control: 10c5387d Table: 2cdb006a DAC: 00000055
[ 6.496288] Process systemd-udevd (pid: 229, stack limit = 0xad090210)
[ 6.503762] Stack: (0xad091e58 to 0xad092000)
[ 6.511148] 1e40: ad091f14 ad091e68
[ 6.518659] 1e60: 801d34bc 8055ebf8 ab4deff8 00000001 00000000 b1b7a000 ad091ecc ad091e88
[ 6.526151] 1e80: 802e8038 ffffffff 76d909f8 b1bbd72c b1bbd704 0000085a 00000000 ad091ee0
[ 6.533717] 1ea0: accaf6c0 ad090000 ad091f2c 80a4c728 00000001 00000000 80ac8b00 80abcfcc
[ 6.541275] 1ec0: ad091f14 ad091ed0 802f2e84 802e7eb0 ad091f30 adbbae40 00043754 00000000
[ 6.548873] 1ee0: 00043754 00000000 ad091f34 00000000 0000000b 76d909f8 0000017b 7fffffff
[ 6.556465] 1f00: 00000000 00000000 ad091fa4 ad091f18 801d54f0 801d263c 7fffffff 00000000
[ 6.564100] 1f20: 00000003 8028dab0 ad091f74 b1b7a000 00043754 00000000 00000002 b1b7a000
[ 6.571698] 1f40: 00043754 b1bbcee4 b1ba11c3 b1ba9988 00000000 00000000 00000000 00000000
[ 6.579269] 1f60: 00000000 00000000 00000034 00000035 00000029 0000002d 00000014 00000000
[ 6.586820] 1f80: 0000017b 01309648 7efc9024 08dbdc00 8010f808 ad090000 00000000 ad091fa8
[ 6.594320] 1fa0: 8010f640 801d5448 01309648 7efc9024 0000000b 76d909f8 00000000 01309ad8
[ 6.601821] 1fc0: 01309648 7efc9024 08dbdc00 0000017b 00020000 00037f78 00050048 013108c0
[ 6.609321] 1fe0: 7efc8f00 7efc8ef0 76d8ac4b 76e95a42 60010030 0000000b 6f5f7075 6f697470
[ 6.616886] [<8055ebf8>] (strlen) from [<801d34bc>] (load_module+0xe8c/0x2cb8)
[ 6.624261] [<801d34bc>] (load_module) from [<801d54f0>] (SyS_finit_module+0xb4/0xcc)
[ 6.631522] [<801d54f0>] (SyS_finit_module) from [<8010f640>] (ret_fast_syscall+0x0/0x1c)
[ 6.638771] Code: e89da800 e1a0c00d e92dd800 e24cb004 (e5d02000)
[ 6.646449] ---[ end trace 34ebc041087254d1 ]---
[ 7.635964] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 7.692006] 8021q: 802.1Q VLAN Support v1.8
[ 7.904508] systemd-journald[175]: Received request to flush runtime journal from PID 1
[ 9.152265] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x5DE1
[ 20.229284] Console: switching to colour dummy device 80x30
[ 68.912685] random: crng init done
[ 74.636969] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
