Ok, I finally had a window of time to work on this more.
Wow, that was a lot of time, research, and stumbling. (As in many many hours) All just to get my WD Live remote unit working with Raspberry Pi and JustBoom Digihat. But how sweet it is now.
I thought I would overview the procedure so that I can contribute back to this forum. Just in case there are any others that would like to know how to get an IR remote working for this setup. (It’s possible that it may only work on this particular Pi model, Ir Remote and version of OSMC, etc.) Disclaimer: This is what worked for me. If there are any other issues anyone has, sorry, I do not have any more info and it is at your own risk.
- Decide how you will work with terminal on OSMC. Although the terminal can be accessed on the Pi and OSMC itself if one has a keyboard and mouse, I found out that if you have a Lan connected to your router from the Pi, along with other computers on the same network, you can access the Pi remotely from another computer. That made it way easier to enter text on the terminal because you can copy and paste directly from website info. So much easier than entering it all manually as one little mistake can make it not work. For that I installed software called ‘Putty’ on my windows 7 desktop. (Download PuTTY: latest release (0.78))
You will need to find out your ip address for your Pi and then enter in the Putty software. Find that on My OSMC home page with the Network icon and Wired listing.
SSH has to be enabled on OSMC to do remote work. You can check and set this on My OSMC home page with the Services icon. If you don’t have it, this worked for me to install/reinstall using terminal:
sudo apt-get install --reinstall ssh-app-osmc
You have to make sure that LIRC is installed and working with OSMC on your Pi. I followed the instructions on the JustBoom site for this. How To Configure JustBoom IR Remote With LIRC • JustBoom (At least up to Step 5. Step 6 did not work for me but it turned out not to matter.) These instructions appear to be intended for their own brand remote which is why I did not originally think it was something I had to follow for my WD Live Remote device setup. They also state Raspbian O/S and I have OSMC. Regardless, apparently seems to be the base set up for all IR remotes. Btw, a great many remotes are already listed in the remotes set up on the home page of OSMC. If yours is not listed, there are also write ups out on the web on how to do custom remote installs but you can research that for yourself. I did not need to do the ‘training’, I’m guessing because my WD Live Remote was already listed.
When I did the sudo reboot, my WD Live IR remote worked along with 5.1 sound and everything else as well.
Hope this helps someone, cheers, m.
Update 020319:
My OSMC crashed and the sd card burned out as result. So, got a new one and downloaded the latest OSMC. 2018.12.1. In this version it was super easy now to get the WD remote working. Didn’t have to do much at all.
I selected the WD Live remote in My OSMC/Remotes by scrolling down to it and confirming. Then went to My OSMC/Pi Config/Hardware Support and changing the gpio_in_pin to 25 and ok. Don’t forget, have to reboot pi to get settings to take place. That’s it, works fine.
Update 12/28/21:
Well, it’s been awhile! Why? Been happily using my RPi3 with OSMC all along. Has worked so well in every way!
But, fell for the newer RPi4 8G with 128G card. :-p So, had to reinstall everything. Wanted a fresh start with the latest OSMC and Kodi. So came back to look at my instructions here. Forgot the details after all that time!
And guess, what? Easy as pi. Lovin’ it all. Digi hat rocks. OSMC still rocks and even better now! It’s incredible what all the contributors have done over the years. I’m so thankful.
Note: One can only use the first port (near power input) of the two HDMI mini ports, if one is using only one monitor. Long story short…caused a world of grief for me and not even the vendor knew about it. It’s not an OSMC issue, it’s default RPi.
Still wish there was a way to increase pass through sound volume but again, that’s not an OSMC thing, it’s just passin’ through. Somehow the base volume of the AV receiver is low so I have to compensate with turning volume way up. If I do not allow pass through, I can take advantage of the Volume amplification in Audio Settings and set it as default for all media, but then I lose my HD and Surround sound and it seems to stutter a bit too. But I can live with the lower volume, there is so much more that is working.
