[Solved] LiveTV Shuttering?
You may need to change view to expert to see it.
Thanks Tom.
Hey,
It’s there:
As Tom says, you have to be in expert view mode.
Thank you both. I found it after changing the view to expert.
And it works!
This won’t be needed after the next update
ah?
Will I need to uncheck the force old status after the update?
No
Sam,
Since last update, shuttering is back :confused:
I still have Force old status enabled, and I didn’t change anything.
What did the update change to LiveTV?
Nothing should have changed, but TVH has been updated.
Need a bit more info.
Can you post a log? Does this happen with all channels or just some?
