I ordered a TV dongle from the official shop, I use it on my Vero4K. Video is shuttering, making it impossible to watch. The audio is alright.
If I use TVHeadend client on Kodi on my Windows 10 PC, I don’t have any issue. It’s only on the vero4K.
I don’t really know where to look to resolve this. Can you help me?
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
So, I selected French as my language, 192.168.0.0/24 as my authorized network, selected network 3 (Sony CXD2837ER DVB-T adapter) and Generic as pre-defined muxes (previously, I used the realtek adapter).
The scan finds 57 muxes and 40 services.
I activated the TVHeadend client, and tested the live tv. Everything worked smoothly.
Then I rebooted the Vero4K just to test if it’s ok after a reboot and… yes
So it seems that my problem was that I used the realtek adapter in the first place
I’m sorry I wasted your time since I found the solution myself
Thanks, and I hope this post will eventually help someone else.
I just tried it again. And if the reboot problem is no longer here, I still have the shuttering issue…
After some time, I have to reboot the vero4k to have a smooth experience with live TV. No problem with the audio, only the video is shuttering. Lots of artefacts, and lots of lags.
Testing here - I get problems when the signal strength is less than about 40dB. But if I select ‘Force old status’ in the DVB Input settings I have no problems. Try that.
