Is there any workaround to access My OSMC through other skins?
Regards.
Regards.
Hi Carlos
Should be availble under Programs -> OSMC Settings
S
Hi Sam.
OSMC Settings is blank at least in the default Confluence skin.
Are you on OSMC RC, and can you take a screenshot or photo so we can see what you mean?
S
Might also be relevant to know what language Kodi is set to.
Now works, maybe it was my mistake and confused it with the addon ‘Configure’ option which is blank maybe cause there is nothing to configure in the My OSMC addon itself xD. ‘Launch’ brings the menu correctly.
Thanks for all. I have another 4 Raspberry Pi 2, just tell me if I can help testing something.
Regards.
