having the problem to start nano
sudo nano /etc/ssh/fstab
Error opening terminal: screen.xterm-256color.
how to solve?
how to solve?
How are you accessing the device?
via ssh
never had this
logout
'screen.xterm-256color': unknown terminal type.
Connection to 192.168.1.185 closed.
tr@T410:~$ ssh osmc@192.168.1.185
solved
user error
was in a screen session…
sorry
Even in screen nano works. Next time - before you execute nano, issue the following command:
export TERM=screen
Then it works. My screen sets the env. variable automatically when started.
Yo can also set it to: “linux” ![]()
