well there are a couple of topics that might lead to that.
When you plugin the memory stick are you getting in the upper part of the screen the message âRemoveable Harddisk mountedâ followed with the name of the disk in the second line? If that is happening that first step ok. If that is not happening than you would need to check the format of your memory stick and if it is generally working. For troubleshooting it would be best to have SSH access to the OSMC and or you should at least know how to create the logfile and upload it to pastebin.
If it is mounted than you generally should have a new entry in the respective Video section with the name of your disk. Also ensure to choose âUnmount Cleanlyâ from that part.
first go to âMy OSMCâ and find out your IP address (under Network) and check if SSH is running (under Service).
With that information from your PC/MAC/⌠use a SSH client (e.g. putty) to access the osmc.
ssh osmc@ with password osmc.
