[Solved] OSMC crashes when playing a mkv extracted from YouTube
Hello
Vero 4k user, on version 2022.03-1.
Using YouTube DL (on my Windows computer), i got the below video in mkv (11,1 Gb) :
Here it’s MediaInfo details :
General
Unique ID : 166777626643858744319428523192727881879 (0x7D7833D865EF39AA0EB84672312BC897)
Complete name : \192.168.1.82\Public\Concerts\Rammstein - Stadium Tour - Prague (2022)\Rammstein - Stadium Tour - Prague (2022).mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 11.1 GiB
Writing application : Lavf58.29.100
Writing library : Lavf58.29.100
IsTruncated : Yes
ErrorDetectionType : Per level 1
Video
Format : VP9
Codec ID : V_VP9
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 60.000 FPS
Default : Yes
Forced : No
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Default : Yes
Forced : No
It plays fine with VLC on Windows.
The file is on a Linux NAS, shared to Kodi using NFS4.
When i try to play it with Kodi on my Vero, it crashes, no display, no network, nothing, i don’t have any other option than to reboot it electrically.
Here’s my log (kodi concerned log file is kodi.old.log) :
https://paste.osmc.tv/ukuwozibop
In case you need specifically the kodi.old.log, here it is : Upload files for free - kodi.old.log - ufile.io
Crash was on the July, 27th around 3:38 pm.
Any idea ?
Thanks.
I’m going to check this out on my Vero 4K+.
But how did you get a 11GB file?
My download is 20.65GB!
My file:
General
Complete name : D:\Rammstein - Live PRAGUE Full Concert 16.5.2022 (2160p_60fps_VP9-160kbit_Opus).webm
Format : WebM
File size : 20.6 GiB
Duration : 1 h 53 min
Overall bit rate : 26.1 Mb/s
Writing application : Lavf58.39.101
Writing library : Lavf58.39.101
Video
Format : VP9
Codec ID : V_VP9
Color space : YUV
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : Opus
Codec ID : A_OPUS
Channel layout : L R
Sampling rate : 48.0 kHz
Bit depth : 32 bits
Language : English
Default : Yes
Forced : No
Plays fine on my Vero 4K+.
https://www.dropbox.com/s/lze3vvqgmooai2u/youtube.mp4?dl=0
Also plays fine on my Vero 4K+ with the [2022.03-1] software release.
Im guessing but did you check your display settings, I would recommend 1920x1080 60Hz. Enable Adjust Refresh Rate and Kodi will switch to 4K when necessary.
Sorry, forgot this post with the summer holidays.
I’m already at 1920x1080@60Hz in Kodi.
I’ll check for refresh rate, but it plays fine now.
@Kontrarian : not the same encoding settings on the file
