Hello,
i just plugged a hifiberry dac+ in my raspbery pi 2 but i can’t see it under Settings/System/Audio. What should i do ?
many thanks !
G.
Hello,
many thanks !
G.
Use MyOSMC config to enable the DAC maybe?
Oups, sorry i forgot that… I now see the soundcard in the Settings/System/Audio but when i select it it doesn’t play movies (no sound & no image), and for music osmac has freezed. It seems also slower when i navigate.
bad luck…
i have a usb keyboard on it, a blutooth dongle, an “official” osmc remote with dongle, and a mouse. Do you think that could be the problem ? This is the latest osmc version
And you have selected it for output in settings/audio?
i did, yes
OK. Do you see it go active? Ie does the green LED light? I had some issues in the past like your, but now it works for me, apart from breaking video.
Does it work if you try playing stuff from the commandline? ($ aplay -l)
What does your config.txt look like?
yes, the green light is lit.
my config file
gpu_mem_1024=64
disable_overscan=1
start_x=1
disable_splash=1
dtoverlay=lirc-rpi
gpu_mem_256=64
gpu_mem_512=64
arm_freq=1000
core_freq=500
over_voltage=2
sdram_freq=500
overscan_scale=1
dtparam=audio=off
dtoverlay=hifiberry-dacplus-overlay
sdtv_aspect=1
dtparam=gpio_in_pin=18
dtparam=gpio_out_pin=17
osmc@osmc:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ HiFi pcm512x-hifi-0
Subdevices: 1/1
Subdevice #0: subdevice #0
thanks for your help
This should =256
I know you are now debugging audio, but you will never get video with 64mb.
it worked !!!
many thanks !!!
