After a crash course in SSH I’ve managed to get to the contents of the kodi.log for you. This is after deleting the walkthrough_completed file and rebooting with no network connection, going through the setup to the point of hitting continue on the licence screen (where nothing happens). I then plugged it into the network and pulled the log, without hitting continue or anything on the UI.
Hello, good evening
I have the same problem with new OSMC (20160303 usb.img) on latest Apple tv1.
After install everything ok until license screen… " I try hitting “Continue” but nothing happens. Like others,
I thought I might just need to wait for it to scroll all the way through the licence, so I did, until it looped back round, still can’t Continue."
Thank you
Issue is definitely present on the pi zero, just trying to install, same symptoms
Only got single power supply cable and one usb cable, have tried using usb keyboard when pi boots to get a console session but it doesn’t seem to recognise the keyboard and continues to boot, tried removing the SD card an putting it in my laptop and copying the “walkthrough_completed” file from a raspberry pi 2, same problem, it just hangs at the “continue” prompt, am at a loss now as I dont have another keyboard I can try and I cant get shell access as it wont work with the external wireless plugged in.
Tried that too, am running Kali on a laptop and put the sd card in the reader, mounted the filesystem, created the file, unmounted the card, put it back in the pi zero, re-booted and it just went straight back to language selection, as mentioned in my previous post even tried copying the file from one card that works in a pi2 mounted on my laptop to a SD card from the pi zero also mounted on my laptop, same thing again, straight back to the language selection, Think I’m probably just better off waiting for the image to be updated tbh, it’s not a big issue
You must have touched the wrong file. Remember when you mount the SD card in another machine’s no longer /walkthrough_completed you want to create, but walkthrough_completed under the mount directory…
