Hi, I got my Vero 4K+ and everything runs really smooth.
Got the optical out and the Logitech Harmony working
Even managed to program “smallstepback” in the keymap
But how do I get spotify (connect) working, like LibreSpot
I messed around with raspotify but no luck
The lib itself is running on OSMC but I don’t see it from my Android Phone
But on on iPhone is visible. On my old system with LibreSpot it did work on my Android too…
This Android is on WIFI in the same network. And Spotify on the Android can see the iPhone
osmc@osmc:~$ sudo systemctl status raspotify
- raspotify.service - Raspotify
Loaded: loaded (/lib/systemd/system/raspotify.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2018-10-05 17:06:35 CEST; 3h 33min ago
Process: 946 ExecStartPre=/bin/chown raspotify:raspotify /var/cache/raspotify (code=exited, status=0/SUCCESS)
Process: 943 ExecStartPre=/bin/mkdir -m 0755 -p /var/cache/raspotify (code=exited, status=0/SUCCESS)
Main PID: 949 (librespot)
CGroup: /system.slice/raspotify.service
`-949 /usr/bin/librespot --name raspotify (osmc) --backend alsa --bitrate 320 --disable-audio-cache --enable-volume-normalisation --linear-volume --initial-volume=100
Oct 05 17:06:35 osmc systemd[1]: raspotify.service: Service hold-off time over, scheduling restart.
Oct 05 17:06:35 osmc systemd[1]: Stopped Raspotify.
Oct 05 17:06:35 osmc systemd[1]: Starting Raspotify…
Oct 05 17:06:35 osmc systemd[1]: Started Raspotify.
Oct 05 17:06:35 osmc librespot[949]: INFO:librespot: librespot (raspotify v0.11.4) ee87904 (2018-08-06). Built on 2018-08-08. Build ID: rRAGOkNs
Oct 05 17:06:35 osmc librespot[949]: WARN:mdns: Failed to register IPv6 receiver: Os { code: 19, kind: Other, message: “No such device” }
edit I just had to enter my username and password in the config…
It’s not as good as LibreSpot but it work. I’m happy enough ![]()
