[SOLVED] RPI.GPIO won't work after fresh install
Hello all,
I had to do a fresh install of OSMC because of some SD Card problems, and I can’t get GPIO to work again (hardware=RaspberryPi2).
I had an constantly updated OSMC before and my scripts worked just fine setting GPIO up and down. Now, whatever I do there is no change on GPIO pins.
I’m using the simplest possible examples but nothing changes on GPIO. No error whatsoever - just nothing happens. I’ve reinstalled rpi.gpio several times, no luck either.
I would try gpio command directly from commandline but I can’t find package in repositories.
I’m stuck with python’s rpi.gpio.
I’ve read, that disabling “device tree” in raspi-config sometimes can do the trick, but there is no raspi-config in OSMC, and I can’t find any similiar option i MyOSMC app.
Anybody have any hints?
Kind regards,
sulti
I’ve not used the gpio utility myself but it seems to be part of the wiringpi package. Raspberry Pi | Wiring | Download & Install | Wiring Pi (It compiled ok on my Pi.)
Edit. Works fine too.
osmc@osmc:/media/29GB/wiringPi/gpio$ sudo ./gpio readall
 +-----+-----+---------+------+---+---Pi 3---+---+------+---------+-----+-----+
 | BCM | wPi |   Name  | Mode | V | Physical | V | Mode | Name    | wPi | BCM |
 |     |     |    3.3v |      |   |  1 || 2  |   |      | 5v      |     |     |
 |   2 |   8 |   SDA.1 |   IN | 1 |  3 || 4  |   |      | 5v      |     |     |
 |   3 |   9 |   SCL.1 |   IN | 1 |  5 || 6  |   |      | 0v      |     |     |
 |   4 |   7 | GPIO. 7 |   IN | 1 |  7 || 8  | 0 | IN   | TxD     | 15  | 14  |
 |     |     |      0v |      |   |  9 || 10 | 1 | IN   | RxD     | 16  | 15  |
 |  17 |   0 | GPIO. 0 |   IN | 0 | 11 || 12 | 0 | IN   | GPIO. 1 | 1   | 18  |
 |  27 |   2 | GPIO. 2 |   IN | 0 | 13 || 14 |   |      | 0v      |     |     |
 |  22 |   3 | GPIO. 3 |   IN | 0 | 15 || 16 | 0 | IN   | GPIO. 4 | 4   | 23  |
 |     |     |    3.3v |      |   | 17 || 18 | 0 | IN   | GPIO. 5 | 5   | 24  |
 |  10 |  12 |    MOSI |   IN | 0 | 19 || 20 |   |      | 0v      |     |     |
 |   9 |  13 |    MISO |   IN | 0 | 21 || 22 | 0 | IN   | GPIO. 6 | 6   | 25  |
 |  11 |  14 |    SCLK |   IN | 0 | 23 || 24 | 1 | IN   | CE0     | 10  | 8   |
 |     |     |      0v |      |   | 25 || 26 | 1 | IN   | CE1     | 11  | 7   |
 |   0 |  30 |   SDA.0 |   IN | 1 | 27 || 28 | 1 | IN   | SCL.0   | 31  | 1   |
 |   5 |  21 | GPIO.21 |   IN | 1 | 29 || 30 |   |      | 0v      |     |     |
 |   6 |  22 | GPIO.22 |   IN | 1 | 31 || 32 | 0 | IN   | GPIO.26 | 26  | 12  |
 |  13 |  23 | GPIO.23 |   IN | 0 | 33 || 34 |   |      | 0v      |     |     |
 |  19 |  24 | GPIO.24 |   IN | 0 | 35 || 36 | 0 | IN   | GPIO.27 | 27  | 16  |
 |  26 |  25 | GPIO.25 |   IN | 0 | 37 || 38 | 0 | IN   | GPIO.28 | 28  | 20  |
 |     |     |      0v |      |   | 39 || 40 | 0 | IN   | GPIO.29 | 29  | 21  |
Thanks!
It helped me to see that my board actually works, and pins can be set.
Aaaaand I’ve found my mistake… I had an ucommented line
GPIO.cleanup()
at the end of my script… :flushed:
Now everything works like a charm.
Regards.
