I installed the rtorrent client on my new Rpi 4 8GB, but when launching it and adding a download or when data transfer occurs, it closes in no time. This is the error output:
Caught SIGBUS, dumping stack:Rate 0.4/ 0.4 KB] [Port: 49150] [U 0/65535] [D 0/65535] [H 0/32] [S 28/31/768] [F 2/128]
rtorrent(+0x13526) [0xa53526]
/lib/arm-linux-gnueabihf/libc.so.6(+0x25cb0) [0xf7857cb0]
/lib/arm-linux-gnueabihf/libtorrent.so.20(+0x844e4) [0xf7c0c4e4]
/lib/arm-linux-gnueabihf/libtorrent.so.20(_ZN7torrent9PollEPoll7performEv+0x85) [0xf7bb0b8e]
/lib/arm-linux-gnueabihf/libtorrent.so.20(_ZN7torrent9PollEPoll7do_pollExi+0x6f) [0xf7bb0ca4]
/lib/arm-linux-gnueabihf/libtorrent.so.20(_ZN7torrent11thread_base10event_loopEPS0_+0x127) [0xf7bd682c]
rtorrent(+0x12482) [0xa52482]
/lib/arm-linux-gnueabihf/libc.so.6(__libc_start_main+0x97) [0xf7849524]
Error: Success
Signal code '1': Invalid address alignment.
Fault address: 0x16ffbad
The fault address is not part of any chunk.
Aborted
I tried another client within Kodi, Elementum, and it works fine.
Yes, I installed it with a simple apt install, with OSMC’s own repositories.
I also installed nginx, php7.3, and rutorrent. But the status of those services does not change anything.
I am trying to compile the latest stable versions of libtorrent (0.13.8) and rtorrent (0.9.8). I don’t have much experience compiling, but I follow the instructions in the INSTALL file. I run ‘autoconf’ to build the ‘configure’ file, and I get this error:
configure.ac:4: error: possibly undefined macro: AC_CONFIG_MACRO_DIRS
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
configure.ac:5: error: possibly undefined macro: AM_INIT_AUTOMAKE
‘configure’ file is generated but when executing it I get this error:
./configure: line 2069: syntax error near unexpected token `scripts'
./configure: line 2069: `AC_CONFIG_MACRO_DIRS(scripts)'
It happens with libtorrent and with rtorrent. I don’t know if I installed all the packages needed to compile or should I do something else.
It was a long time since I did a own compile of tTorrent. Been using the .Deb package, but i did notice that the user running rtorrent needs two things in their home folder. .rtorrentrc and a folder named .rtorrentsession. I’m mobile right now and can’t check correct spelling/caps.
I finally managed to compile, install and run rtorrent without problems, tested for several days.
When compiling libtorrent I used the following option:
./configure --enable-aligned
So in Rbpi4 I have installed versions of rtorrent 0.9.8 and libtorrent 0.13.8
Now I would like to know how to get the corresponding .deb packages.
I already installed using ‘sudo make install’. I would like to build the .deb packages of this build, so that I can delete all the folders and files in this build.
I’ve never build a .deb package personally, but if i was building a newer version of something that has a deb package, I would look at that .deb package that is in the distro, like untar it’s content and play around to see if there was just (which I doubt), replace the files? To get an idea how it’s supposed to work, else I bet there are more then a handful tutorials on google how to build your own .deb package.
