Hi everyone,
This is happening on a new RPi3 that I set up for the first time yesterday afternoon. It’s my first OSMC experience too, and I must say it’s not going well. I’ve been getting sad face loops all the time yesterday, every time because I unplugged the device after OSMC froze up. Never was I able to recover my guisettings or my database, but I had to start fresh each time by renaming/deleting /home/osmc/.kodi.
The reason for all past crashes before this one was multitasking: I let Kodi scan/import a large source folder from .nfo files while installing and configuring add-ons. Apparently the RPi3 can’t handle that much load at once - it froze, and the only way to get it back was to unplug it.
After unplugging, it would be stuck in the endless sad face loop until I deleted the /.kodi folder. I tried at least salvaging guisettings.xml, but I got the sad face loop every time. So I had to start from scratch each time: set up HTTP access, download skin, add sources…
After doing that about 3-4 times, losing everything, starting from zero, making progress, losing everything, starting from zero again… I realized I had to leave it alone while it was populating the library. So I did, and went to bed last night with it scanning a large folder.
And this morning, it was frozen again. I was able to see the dimmed screen with the UI where I left it - the refresh library process had finished. But it was completely unresponsive to CEC and keyboard. SSH was unable to connect.
So I unplugged it yet again, and now I’ve lost all settings and database yet again… and with that, the better part of yesterday.
I’ll keep my questions short.
Is there any way to reboot OSMC when it’s frozen, short of unplugging?
Is there a way to keep guisettings.xml after unplugging? Kodi wasn’t this sensitive on Windows, where I’ve been running it before the RPi. Just wondering why it won’t start with an old guisettings.
I’d love to know the reason for this endless loop, and why it crashed while just sitting there not doing anything. Here’s kodi.log… not sure if it helps though: http://paste.osmc.io/jujulebilu.coffee
I’d love to get behind this, and I’d appreciate any help. Thank you.
I found the skin to be the problem that way.
