Hi. First of all, sorry for my english.
Since the last update of osmc, i’m stuck with a sad face after the reboot.
I’m using a raspberry Pi 2.
Here is mylog file: http://paste.osmc.io/puhivufofe
We need a kodi log.
paste-log ~/.kodi/temp/kodi.log
Do you use MySQL? Is the server available?
Yes i use mysql ad server was down but now he’s up and the problem remains the same.
Here is the log.
18:13:54 56.615875 T:1956597760 ERROR: CMediaSourceSettings: sources.xml file does not contain <sources>
paste-log ~/.kodi/userdata/sources.xml
Ok problem solved. You put me on the right path. My source fils was a mess. Thanks a lot.
Yep, was just gonna get you try this.
