Using latest 2017.044-1 on rasbperry pi 2
When I try to create a screenshot, I get a popup “Search folder” window
This floating window appears twice, I mean, I have to close it two times to get back to the previous screen.
It happens using keyboard’s Ctrl+S, but also happens via SSH using
kodi-send --action=“takescreenshot”
Any idea how to fis this?
It’s not a bug. You have to use that screen to direct Kodi where to place the screenshot. It only occurs on the first attempt to take a screenshot. After that, all subsequent screenshots will be placed in that location.
I feel so noob
screenshots are getting saved anyway, inside /home/osmc/.kodi/temp that’s why I didn’t suspect.
Thanks very much for your help
