OSMC on Raspberry pi3.
Since I upgraded to November 2020 release my OSMC raspberry box is no longer detecting the CXD2880 Sony DVB-T tuner.
It was running fine before the upgrade and is still running fine with Raspberry OS.
Not an HW problem.
From what I can understand this new kernel do not have (or support) cxd2880 modules.
dmesg doesn’t contain anything about Sony or cxd2880.
Where can I find a kernel that supports this HW?
Post logs – we need to know what kernel you are on.
root@osmc:/home/osmc# uname -a
Linux osmc 4.19.122-2-osmc #1 SMP PREEMPT Sat Jul 4 02:39:56 UTC 2020 armv7l GNU/Linux
root@osmc:/home/osmc# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
root@osmc:/home/osmc# cat /etc/apt/sources.list
deb Index of /debian buster main contrib non-free
deb Index of /debian buster-updates main contrib non-free
deb http://security.debian.org/ buster/updates main contrib non-free
deb http://apt.osmc.tv buster main
This kernel hasn’t been updated in months.
Which version were you using before where the Sony tuner worked?
Have you verified the device is still functioning on another machine?
Good question … Wished I knew …, but unfortunately I don’t
Yes even more so … works on the same box with Raspberry OS 10
SOLVED !!
Just did the following:
apt update
apt full-upgrade
APT auto-remove
after installing everything reboot.
now dmesg gives me
[ 11.179459] dvbdev: DVB: registering new adapter (CXD2880)
[ 11.249161] cxd2880: cxd2880_attach: CXD2880 driver version: Ver 1.4.1 - 1.0.5
[ 11.249304] cxd2880 spi0.0: DVB: registering adapter 0 frontend 0 (Sony CXD2880)…
[ 11.252969] cxd2880_spi: cxd2880_spi_probe: Sony CXD2880 has successfully attached.
[ 23.133941] cxd2880 spi0.0: DVB: adapter 0 frontend 0 frequency 0 out of range (174000000…862000000)
[ 25.577061] cxd2880: cxd2880_set_frontend: sys:3 freq:610000000 bw:8
[ 26.597482] cxd2880: cxd2880_set_frontend: tune result 0
Wasn’t the kernel after all !!
