Device: Rasp Pi B
Installation media: SDcard 8GB Class 10
Connection: Wired
Power Supply Type: EU Wallplug from pihut.com
Power specs: 5V 2A
Peripherals: none
Storage Device (incl. Network Sharing Protocol): NFS, SMB
OSMC version: VERSION_ID=“2015.08-1”
XBMC version:Kodi (15.1). Platform: Linux ARM 32-bit
Codecs: mpeg2, vc1
Audio/Video Output: HDMI
Overclocked: High
Config.txt Extras: none
Hello,
The ‘transport buttons’ on my TV Remote are not working (play, pause, stop buttons) with OSMC. I used to run Raspbmc on the same RPi but recently installed OSMC. With Raspbmc the transport buttons worked fine. I have another RPI connected to the same TV with another dristro and the transport buttons work fine.
Most buttons do work. But not the transport buttons like play pause stop etc.
The TV they are connected to is a Panasonic Viera.
I tried switching to a non-cec anabled HDMI port and back.
I checked that I have hdmi_ignore_cec_init=1 in config.txt. I tried shutting the TV off and remove all cables for an hour.
I replugged the HDMI cable on both sides. I even tried only connecting this RPi as the sole HDMI device.
When I select ‘player’ from Viera Link, it switches to the RPi running OSMC, so it is recognised as a player.
The RPi is updated and has rebooted multiple times.
Any ideas?
