[SOLVED] USB and network disconnection
Just bought a Raspberry Pi 2 B and I have a problem, after a few minutes OSMC says in Spanish “Disco desmontado de forma no segura” something like hard drive ejected using unsafe methods. Or something similar. It happens 2 of every 5 times I place the cursor on the “…” option. When it does that the ethernet shuts down as well. After 2 or 3 times it usually reboots.
I have a keyboard, an ethernet and a extenral hdd attached to the Raspberri. Sorry about my grammar and stuff, it’s really late here and I’m really tired of trying all day.
Thanks in advance.
Try adding max_usb_current=1 to your config.txt If that doesn’t help it sounds like you don’t have enough power, do you ever see a rainbow square in the top right corner of the screen?
Yes, I see the rainbow square every once in a while.
EDIT: I’ll try that when I finish re-installing it, thanks. The rainbow means not enought power? I’ll try another wire or something. Thanks
The rainbow means dangerously low power, could be the power supply or cable you’re using
Ok I just used the external battery charger for my phone and the rainbow dissapeared. I have an old electric installation in my house so some plugs could have less power than others.
Thank you deeply Dilligaf, now I’ll solve the problem :smiley:
