I am running into a suspend / resume issue with my 4K+.
Details:
OSMC running Kodi 18.3-RC1
Compiled 2019-05-21
Settings/System > Power saving >
Shutdown function timer = 90 mins
Shutdown function = Suspend
The device appears to suspend correctly after 90 mins and I see a red light on the front LED.
When I click the remote, it seems to wake up, but will not take any further input from the remote. I tried to remove the re-plug in the usb dongle for the remote.
After waiting this out for about 10 mins, I ssh’d into the machine and rebooted.
Not sure why the device is not resuming correctly, and not sure what further info I can provide.
Thanks for any pointers / assistance to help solve this.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
No longer happening on both my 4K+ units after I disabled the screensaver. I went to the default installed “dim” and “black screen” screensaver options on each unit, and this does not cause the freeze issue.
Solved for me … ty fzinken for the info / pointers
Same here. My Vero 4k+ looks like not getting input from remote control after resuming from suspend. I followed tnedor’s suggestion to disable screen saver or to switch to “dim” or “black” screen saver. Resuming from suspend works now.
I think there is an issue with Picture Slideshow Screensaver.
I have had similar trouble, but noticed a possibly relevant log message each time it happens:
kodi.2019-08-07.debug.log:2019-08-07 08:26:38.136 T:4066377728 ERROR: CPythonInvoker(9, /home/osmc/.kodi/addons/screensaver.picture.slideshow/default.py): script didn’t stop in 5 seconds - let’s kill it
I have also seen the unexpected wakeup after manual suspend, so I am going to quit using manual suspend and see if that avoids triggering this problem.
