Can anyone explain why I’m getting this warning?
I can access the HDD without a problem in the server
BUT I can’t access it via NFS. That’s why I discorvery this warning
osmc@osmc:~$ showmount -e localhost
clnt_create: RPC: Program not registered
dmesg:
[ 7.605237] sd 1:0:0:0: [sdb] Write Protect is off
[ 7.605254] sd 1:0:0:0: [sdb] Mode Sense: 47 00 10 08
[ 7.605563] sd 1:0:0:0: [sdb] No Caching mode page found
[ 7.605576] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 7.622595] sdb: sdb1
[ 7.625178] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 8.558438] EXT4-fs (sda1): warning: maximal mount count reached, running e2f sck is recommended
[ 8.601237] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.921563] EXT4-fs (sdb1): warning: maximal mount count reached, running e2f sck is recommended
[ 8.989507] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
