Some buttons stopped working on remote
Remote for original 4k, play, stop, back buttons have all stopped working. Anything I can try?
To my recollection those buttons go through eventlircd under a separate pathway.
Are you using this remote on an OSMC device (Pi / Vero)?
Do you see a blue light when you press these buttons?
Using on V4k. Yes, blue lights shows up on all button presses. Thanks
Can you try on another osmc device or reinstall osmc?
If you have two remotes, make sure you have not mixed up the dongles if they are different revisions
