Okay, I have pressed once following buttons:
button under yellow
button under blue
button under green
button under red
Record Button
Start Button
Astersik (*) Button
Hash Button (#)
Close Button.
And here is what my log says:
19:35:49 T:3025018880 DEBUG: Keyboard: scancode: 0x0e, sym: 0x0008, unicode: 0x0008, modifier: 0x0
19:35:49 T:3025018880 DEBUG: OnKey: backspace (0xf008) pressed, action is Back
19:35:49 T:3025018880 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
19:35:49 T:3025018880 DEBUG: ------ Window Deinit (Settings.xml) ------
19:35:49 T:3025018880 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
19:35:49 T:3025018880 DEBUG: ------ Window Init (Home.xml) ------
19:36:06 T:3025018880 DEBUG: Keyboard: scancode: 0x1d, sym: 0x0132, unicode: 0x0000, modifier: 0x40
19:36:06 T:3025018880 DEBUG: OnKey: ctrl-leftctrl (0x1f0d0) pressed, action is
19:36:06 T:3025018880 DEBUG: Keyboard: scancode: 0x18, sym: 0x006f, unicode: 0x006f, modifier: 0x40
19:36:06 T:3025018880 DEBUG: OnKey: ctrl-o (0x1f04f) pressed, action is ActivateWindow(TVRecordings)
19:36:06 T:3025018880 DEBUG: Activating window ID: 10616
19:36:06 T:3025018880 DEBUG: ------ Window Deinit (Home.xml) ------
19:36:06 T:3025018880 DEBUG: ------ Window Init (MyPVRRecordings.xml) ------
19:36:06 T:3025018880 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
19:36:06 T:3025018880 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
19:36:06 T:3025018880 DEBUG: ------ Window Init (Home.xml) ------
19:36:06 T:3025018880 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
19:36:07 T:3025018880 DEBUG: Keyboard: scancode: 0x1d, sym: 0x0132, unicode: 0x0000, modifier: 0x40
19:36:07 T:3025018880 DEBUG: OnKey: ctrl-leftctrl (0x1f0d0) pressed, action is
19:36:07 T:3025018880 DEBUG: Keyboard: scancode: 0x22, sym: 0x0067, unicode: 0x0067, modifier: 0x40
19:36:07 T:3025018880 DEBUG: OnKey: ctrl-g (0x1f047) pressed, action is ActivateWindow(TVGuide)
19:36:07 T:3025018880 DEBUG: Activating window ID: 10617
19:36:07 T:3025018880 DEBUG: ------ Window Deinit (Home.xml) ------
19:36:07 T:3025018880 DEBUG: ------ Window Init (MyPVRGuide.xml) ------
19:36:07 T:3025018880 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
19:36:07 T:3025018880 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
19:36:07 T:3025018880 DEBUG: ------ Window Init (Home.xml) ------
19:36:09 T:2894730272 DEBUG: script.module.osmcsetting.updates : - blurp 662 - Home.xml
19:36:09 T:3025018880 DEBUG: Keyboard: scancode: 0x1d, sym: 0x0132, unicode: 0x0000, modifier: 0x40
19:36:09 T:3025018880 DEBUG: OnKey: ctrl-leftctrl (0x1f0d0) pressed, action is
19:36:09 T:3025018880 DEBUG: Keyboard: scancode: 0x14, sym: 0x0074, unicode: 0x0074, modifier: 0x40
19:36:09 T:3025018880 DEBUG: OnKey: ctrl-t (0x1f054) pressed, action is ActivateWindow(TVChannels)
19:36:09 T:3025018880 DEBUG: Activating window ID: 10615
19:36:09 T:3025018880 DEBUG: ------ Window Deinit (Home.xml) ------
19:36:09 T:3025018880 DEBUG: ------ Window Init (MyPVRChannels.xml) ------
19:36:09 T:3025018880 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
19:36:09 T:3025018880 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
19:36:09 T:3025018880 DEBUG: ------ Window Init (Home.xml) ------
19:36:11 T:3025018880 DEBUG: Keyboard: scancode: 0x1d, sym: 0x0132, unicode: 0x0000, modifier: 0x40
19:36:11 T:3025018880 DEBUG: OnKey: ctrl-leftctrl (0x1f0d0) pressed, action is
19:36:11 T:3025018880 DEBUG: Keyboard: scancode: 0x2a, sym: 0x0130, unicode: 0x0000, modifier: 0x41
19:36:11 T:3025018880 DEBUG: OnKey: ctrl-shift-leftshift (0x3f0d2) pressed, action is
19:36:11 T:3025018880 DEBUG: Keyboard: scancode: 0x32, sym: 0x004d, unicode: 0x004d, modifier: 0x41
19:36:11 T:3025018880 DEBUG: OnKey: ctrl-shift-m (0x3f04d) pressed, action is PlayerControl(ShowVideoMenu)
19:36:14 T:3025018880 DEBUG: Keyboard: scancode: 0x1d, sym: 0x0132, unicode: 0x0000, modifier: 0x40
19:36:14 T:3025018880 DEBUG: OnKey: ctrl-leftctrl (0x1f0d0) pressed, action is
19:36:14 T:3025018880 DEBUG: Keyboard: scancode: 0x13, sym: 0x0072, unicode: 0x0072, modifier: 0x40
19:36:14 T:3025018880 DEBUG: OnKey: ctrl-r (0x1f052) pressed, action is
19:36:14 T:3025018880 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
19:36:18 T:2814694432 DEBUG: Thread JobWorker 2814694432 terminating (autodelete)
19:36:20 T:3025018880 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-arm.so)
19:36:20 T:3025018880 DEBUG: Unloading: /ImageLib-arm.so
19:36:21 T:3025018880 DEBUG: Keyboard: scancode: 0x7d, sym: 0x0136, unicode: 0x0000, modifier: 0x400
19:36:21 T:3025018880 DEBUG: GetActionCode: Trying Hardy keycode for 0x20f200
19:36:21 T:3025018880 DEBUG: Previous line repeats 3 times.
19:36:21 T:3025018880 DEBUG: OnKey: meta-0 (0x20f200) pressed, action is
19:36:21 T:3025018880 DEBUG: Keyboard: scancode: 0x38, sym: 0x0134, unicode: 0x0000, modifier: 0x500
19:36:21 T:3025018880 DEBUG: OnKey: alt-meta-leftalt (0x24f0d4) pressed, action is
19:36:21 T:3025018880 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x500
19:36:21 T:3025018880 DEBUG: OnKey: alt-meta-return (0x24f00d) pressed, action is
19:36:23 T:3025018880 DEBUG: Keyboard: scancode: 0x37, sym: 0x010c, unicode: 0x0000, modifier: 0x0
19:36:23 T:3025018880 DEBUG: OnKey: numpadtimes (0xf062) pressed, action is
19:36:24 T:3025018880 DEBUG: Keyboard: scancode: 0x45, sym: 0x012c, unicode: 0x0000, modifier: 0x1000
19:36:24 T:3025018880 DEBUG: OnKey: numlock (0xf0da) pressed, action is
19:36:24 T:3025018880 DEBUG: Keyboard: scancode: 0x38, sym: 0x0134, unicode: 0x0000, modifier: 0x1100
19:36:24 T:3025018880 DEBUG: OnKey: alt-leftalt (0x4f0d4) pressed, action is
19:36:24 T:3025018880 DEBUG: Keyboard: scancode: 0x51, sym: 0x0103, unicode: 0x0000, modifier: 0x1100
19:36:24 T:3025018880 DEBUG: OnKey: alt-numpadthree (0x4f073) pressed, action is
19:36:24 T:3025018880 DEBUG: Keyboard: scancode: 0x4c, sym: 0x0105, unicode: 0x0000, modifier: 0x1100
19:36:24 T:3025018880 DEBUG: OnKey: alt-numpadfive (0x4f075) pressed, action is
19:36:24 T:3025018880 DEBUG: Keyboard: scancode: 0x45, sym: 0x012c, unicode: 0x0000, modifier: 0x0
19:36:26 T:3025018880 DEBUG: Keyboard: scancode: 0x38, sym: 0x0134, unicode: 0x0000, modifier: 0x100
19:36:26 T:3025018880 DEBUG: OnKey: alt-leftalt (0x4f0d4) pressed, action is
19:36:26 T:3025018880 DEBUG: Keyboard: scancode: 0x3e, sym: 0x011d, unicode: 0x0000, modifier: 0x100
19:36:26 T:3025018880 DEBUG: OnKey: alt-f4 (0x4f093) pressed, action is
19:36:29 T:3025018880 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
19:36:29 T:3025018880 DEBUG: OnKey: return (0xf00d) pressed, action is Select
So, what may be wrong? I think my settings are right, or what can you read from these results?
