My vero 4k + have worked flawless for years, but yesterday the picture disappeard. I can hear the sound though. Experimented with different hdmi cables, and the vero 4k is even tested straight to the tv. The problem is with both 1080 p and 4k. Nothing seems to work. Any thoughs or tips?
Can you see the menus?
Yes I can
reproduce the issue
upload the log set (all configs and logs!) either using the
Solved, it was a simple TV issue. Just needed to unplug the tv from powersocket. Must have caused an error to be on standby on /off for too long.
