I have a Vero 4k bought in mid-August 2018. Approx. every 4 weeks the sound disappears. If you turn up the volume completely, you can faintly hear it. After reinstallation, the sound works again until it disappears again a month later. Reboot does not help. From the time I did the reinstallation I do not change anything in settings.
I can not remember exactly how long the problem has been there, but more than a year so it has existed over many Kodi releases. Vero 4K is connected to HDMI to an LG C8 TV.
reproduce the issue
If I was to guess I would say that somehow Kodi’s internal volume is getting turned down. If your using CEC and a AVR/soundbar the volume adjustment only sends CEC commands so adjustment of internal volume is a bit trickier if it gets turned down. If it happens again I would suggest looking at the web interface or a Kodi remote on a phone app and see if it is showing the volume turned down there and turn it up.
Since you said every 4 weeks - so basically once a month. Could it be a tv firmware update? Have you tried unplugging the hdmi cable from the tv and plugging it back in when you lose sound?
Thanx! 5 days after reinstall the sound disappeared again. I Downloaded a Kodi remote app and checked the internal sound volume and it was turned down.
I do not know why this happens, but I can live with the solution that I have to turn up the internal sound with the Kodi app from time to time.
