Adam1V
13 September 2018 19:58
1
Ive got a couple of small video files which keep dropping sound, after around 60 seconds I get no sound.
Testing the video locally, there is no issues.
media info
Video
Format : AVC
Format profile : High@L3
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 42 min 49 s
Bit rate : 1 093 kb/s
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.148
Stream size : 335 MiB (88%)
Writing library : x264 core 152 r2851 ba24899
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Statistics Tags Issue : mkvmerge v21.0.0 (‘Tardigrades Will Inherit The Earth’) 64-bit 2018-06-06 09:02:24 / Lavf57.79.100
FromStats_BitRate : 2560132
FromStats_Duration : 00:42:49.152000000
FromStats_FrameCount : 61598
FromStats_StreamSize : 822170429
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Format settings : Joint stereo
Codec ID : A_MPEG/L3
Codec ID/Hint : MP3
Bit rate mode : Constant
Bit rate : 128 kb/s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Compression mode : Lossy
Stream size : 39.2 MiB (10%)
Writing library : LAME3.99.5
Default : Yes
Forced : No
FromStats_BitRate : 95924
FromStats_Duration : 00:42:49.220000000
FromStats_FrameCount : 110647
FromStats_StreamSize : 30806458
any thoughts?
It’d help to know what device you’re using.
Adam1V
13 September 2018 20:57
3
Sorry, Vero 4K, latest OS
What are you testing on as a comparison?
Can you enable debug logging and upload a full set of logs?
Adam1V
15 September 2018 14:49
5
Hi @sam_nazarko , ive uploaded the logs to: https://paste.osmc.tv/okarasiniz
Testing on a windows machine using VLC
many thanks
Adam1V
17 September 2018 14:33
6
Hi Sam,
Is there anything in this log thats jumping out as an obvious cause to the sound dropping?
at a glance I cannot see anything regarding audio drops
<audiodevice default="true">ALSA:default</audiodevice>
<channels>8</channels>
indicates you’ve configured
“Default (AML-M8AUDIO Analog), PCM”
with a 5.1 speaker configuration at settings->system->audio .
Is this intended?
What device is connected to the Vero and what port is used for audio (analog, S/PDIF, HDMI)?
Adam1V
17 September 2018 15:31
8
Hi, no that’s not intended.
I’m using hdmi audio to a demon Reciever
Please change this to HDMI.
