Sound drops
as soon as a play a movie sound drops tried reset of av and vero v
then play movie starts ok then drops again, any help please
log: https://paste.osmc.tv/rawijicubo
many thanks
Disable “Sync Playback to Display”
just drops again, never had any problems regarding audio before, not touched any setting, but now plays a few seconds to a few minutes then drops
Hi, I notice a few inconsistencies:
Output configuration: Optimized ===> Default: Best match
DTS-HD capable receiver: true
DTS capable receiver: true
  1. We recommend to use Best match for the (audio) output configuration in the settings.
  2. Believing the provided data, your connected device is not able to process DTS audio data
====================== Audio Cap =================== k3dRrf31
CodingType MaxChannels SamplingFreq SampleSize
PCM, 2 ch, 32/44.1/48/96/192 kHz, 16/20/24 bit
AC-3, 6 ch, 32/44.1/48 kHz, MaxBitRate 640kb/s
Dobly_Digital+/ATMOS, 8 ch, 32/44.1/48 kHz, AFCDepValue 0x1
MAT, 8 ch, 48 kHz, AFCDepValue 0x3
---------------------- Audio Cap END --------------- k3dRrf31
thanks will try that, DTS through LG tv not possible
i did change hdmi input in av and played for about 15 min without any drops so gonna try a factory reset of av, arcam tend to have the odd gremlin that a reset usually fixes
Did this work for you?
yes reset av, thanks
