Seems it’s the same, can’t say for sure yet (it’s a long read). Let say it is for a moment (hoping someone would still look at my logs just to be sure nothing else is off) it is the exact same issue.
I have now changed to OMXPlayer instead of MMAL. And see how that goes.
Downgrading the kernel is a road I’d like to take if any solution (update) doesn’t come by soon enough. I can wait this out a bit, or if nothing else can be found and it’s 100% sure the same problem of course.
Not sure yet. I’ll test OMXPlayer setting now.
edit/ps: Is this the same reason YouTube and video playback, if you start a video, sometimes the sound only kicks in after 2-3 seconds ? Or this is totally unrelated ? Sometimes I have to wait for sound to start, sometimes not.
I think debug logs would be more helpful, you can turn this on via myosmc. If you edit the log level line in the advancedsettings.xml to:
<loglevel>1</loglevel>
Then restart kodi, It won’t show on screen that debug logs are on. Wait for the issue to occur again, restart kodi and uploads logs; then debug logs can be turned off.
