platon
4 December 2022 20:03
1
i have a jbl bar 5.1 with detachable speakers. this bar supports only dts and dolby.
which check marks do i need to activate in the sections ‘sound’?. i’ve selected already ‘passthrough’.
do i need choose 5.1 settings? or leave it on 2.0? i thought changing this can cause some trouble.
With passthrough, it doesn’t matter how many channels you set. If you have connected the JBL via HDMI and it supports PCM multi-channel sound (it would be unusual if it didn’t) then you should set channels to 5.1. Have a look here:
This wiki article should cover all your general questions about how to connect up your OSMC device to get the best audio possible. There’s also a section with explanations of some of Kodi’s audio settings as well as information about the audio capabilities of our OSMC devices.
Supported devices
OSMC supports a range of devices: All Raspberry Pis and our own Vero series (Vero 1, Vero 2, Vero 4K, Vero 4K + and Vero V).
Veros have an HDMI port for video and audio, a 3.5mm port for analogue au…
