I am unable to get sound through my 3.5 jack. From searching I have found that you should put the output device on analogue, which does not exist for me and also this:
hdmi_ignore_edid_audio=1
I’ve put that in config-user however no dice. Any ideas?
No luck unfortunately,
I’ve ruled out a hardware failure because in Raspberry PI OS its working fine by forcing jack output through raspi-config. I don’t know what raspi-config actually changes to make it work but maybe I can try putting that in a config somewhere if anyone knows what it does?
I just found out that using a controller there are no GUI sounds. I was trying to use the GUI sounds to figure out if the audio was working so in the end I am not sure what is/was needed however dtoverlay=pisound
dtparam=audio=on
works for me so im just sticking with that, but just as an FYI there is apparantly a controller GUI sound bug. (might be skin related idk, but it’s not a big deal for me )
