I am very happy vero 4K user. It is really great kodi box. Everything works perfect. Thanks for that OSMC team.
Just such question: can Vero 4K play on the same time 24bit/192kHz music (Flac file: 2.0 stereo) through HDMI and SPDF optical output.
I tested it yesterday (it was still on april version).
Vero 4K is connected with HDMI cable and with optical cable to Denon AVR-X2200W
Vero 4K audio output is configured as 5.1 with passthrough enabled to everything possible.
Then I listen to music what ever file Flac or WavPack (WV files) 16bit/44.1kHz or 24bit/96kHz or even 24/192kHz everything plays fine and my Denon receiver shows 44.1kHz or 96kHz or 192kHz accordingly.
But if I switch to optical input SPDF my Denon receiver play the same files ok ,but just 16bit/44.1kHz and 24bit/96kHz. Receiver shows/ confirms 44.1kHz or 96kHz output.
But with music files 24/192kHz with SPDF optical cable is nothing, just silent.
I know that I have to provide logs, and Vero4K oudio setings. I will do that tomorrow, After some more testing.
So I lost, maybe it is Denon AVR -X2200W fault, maybe AVR internal DAC can not play 24/192kHz stereo music through optical cable (SPDF input)
Mabe somebody have similar Denon receiver and tried it with 24/192kHz music with optical input?
