Speed up response time on tv remote
Not sure if this is the right section, but.
I’m using osmc on a rpi2 and 99% of the time it’s with my Philips tv remote. The navigation is rather slow if you’re comparing with yatse remote from the app store.
And second, on yatse I’m able to long press the OK button to access content menu I think it’s called. Long press on my tv remote think I’m clicking OK numerous times rather then long press it.
Is it possible to speed up the response time and make a long pass on the OK button work as in app remote?
Thanks in advance,
H
Try changing the repeat settings in CEC Settings
Where can I configure my remote? I didn’t find the one I’m using under My Osmc and remotes sadly.
It sounds like you are using CEC
